interval/density/probabilistic forecasts
ac_1
Unread post by ac_1 »
Is there a "vanilla" example of generating & evaluating interval/density/probabilistic forecasts in RATS i.e. how to backtest results from fan charts?
Cheers,
Amarjit
Re: interval/density/probabilistic forecasts
ac_1 wrote:Hi Tom,
Cheers,
Amarjit
I have no idea what you mean. A "fan chart" is a a way to present probabilities, not a way to compute them. It also shows the probability distribution at each separate horizon, but doesn't tell you anything about what a typical multi-period path might look like.
ac_1
My question is then, how do I generate & evaluate interval forecasts in RATS, as I can for point forecasts, as in https://estima.com/docs/RATS%2010%20Use ... f#page=186 ?
You mean, like confidence bands? Isn't that covered on the next page of the User's Guide?
