Dynamic Conditional Beta
Narci4269
Unread post by Narci4269 »
Hi Tom. I´m trying to include Dynamic Conditional Betas (DCB) according to Engle (2016). Here is my code:
cal(irregular)
all 1734
open data I:\EAFIT\Tesis\GPRK\Accion_GPRK_diaria_Final.xls
data(format=xls, org=obs)
**print(win = 'datos')
***** Data transformed *****
set us10y = us_10y; set ca10y = ca_10y; set caus = cad_usd; set eurus = eur_usd
dofor i = us10y ca10y embi_col smb hml rf erm
   set %s('r'+%l(i)) = i{0} / 252
end dofor
dofor i = gprk ecp gte pxt fec cne sp500 tsx brent vix us10y caus eurus copper
   set %s('l'+%l(i)) = log(i{0})
end dofor
dofor i = lgprk lecp lgte lpxt lfec lcne lsp500 ltsx rembi_col lus10y lbrent lvix lcaus leurus lcopper
   set %s('d'+%l(i)) = %if(%valid(i{0} - i{1}),(i{0} - i{1}),0)
end dofor
set dlptfw = wgprk*dlgprk+wecp*dlecp+wgte*dlgte+wpxt*(dlpxt - dlcaus)+wfec*(dlfec - dlcaus)+wcne*(dlcne - dlcaus)
set dlptfs 1 685 = (dlgprk + dlecp + dlgte + (dlpxt - dlcaus) + (dlcne - dlcaus))  / 5
set dlptfs 686 1734 = (dlgprk + dlecp + dlgte + (dlpxt - dlcaus) + (dlcne - dlcaus) + 1*(dlfec - dlcaus)) / 6
dofor i = dlpxt dlfec dlcne
   set %s(%l(i)) = i{0} - dlcaus
end dofor
dofor i = dlgprk dlecp dlgte dlpxt dlfec dlcne dlsp500 dlbrent dlcopper dlptfw dlptfs
   set %s('r'+%l(i)) = 100 * (i{0} - rf)
end dofor
dofor i = rsmb rhml rerm dlbrent drembi_col dleurus dlcopper dlus10y
   set %s(%l(i)) = 100 * i{0}
end dofor
***** GARCH Factors - BRENT *****
dec symm[series] hsfac(4,4) hsptw1(5,5) hsptw2(3,3) dcb(4,1)
clear(zeros) hsfac hsptw1 hsptw2 dcb
set d1 = t>=1521.and.t<=1524; set d2 = t==595; set d3 = t==1404
system(model = eqfac)
variables rdlsp500 rsmb rhml rdlBrent
lags 1 to 2
estimate(noprint, resids = rfac, noftest)
garch(noprint, model=eqfac, mv=DCC, DCC=CDCC, p=1, q=1, hmatrices=hmfac, pmethod=simplex, piters=50, robusterros, $
      method=bhhh, iters=500, mvhseries=hsfac, distrib=t, asymm, stdresid=zfac, rvectors=r2fac, xreg) / $
      # d1 d2 d3
set mkptw1 = 0.0; set brptw1 = 0.0; set sbptw1 = 0.0; set hlptw1 = 0.0
set mkptw2 = 0.0; set brptw2 = 0.0
linreg(noprint, robust, define = eqptw1) rdlgprk / uptw1
# constant rdlsp500 mkptw1 rsmb sbptw1 rhml hlptw1 rdlBrent brptw1
group modpfw1 eqfac eqptw1
***** DCC *****
garch(model=modpfw1, mv=DCC, DCC=CDCC, p=1, q=1, hmatrices=hmptw1, pmethod=simplex, piters=50, robusterros, $
      method=bhhh, iters=500, mvhseries=hsptw1, distrib=ged, asymm, stdresid=zptw1, rvectors=rptw,  $
      hadjust=%(hsptw1(1,1)=hsfac(1,1),hsptw1(1,2)=hsfac(1,2),hsptw1(1,3)=hsfac(1,3),hsptw1(1,4)=hsfac(1,4), $
                hsptw1(2,2)=hsfac(2,2),hsptw1(2,3)=hsfac(2,3),hsptw1(2,4)=hsfac(2,4), $
                hsptw1(3,3)=hsfac(3,3),hsptw1(3,4)=hsfac(3,4),hsptw1(4,4)=hsfac(4,4))) / $
      rdlsp500 rsmb rhml rdlBrent rdlgprk
In hadjust I want to include a series called dcb(4,1). Each one has the calculation inv(%xsubmat(hmptw1(t),1,4,1,4))*tr(%xsubmat(hmptw1(t),5,5,1,4)).
The first series of dcb would have in every row an updated value (for each t) for the first parameter, Second series would a series for second parameter and so on. After that, I would create 4 series in hadjust: mkptw1 = rdlsp500*dcb(1,1), sbptw1= rsmb*dcb(2,1), hlptw1=rhml*dcb(3,1), and brptw1=rdlBrent*dcb(4,1)
I don't know how to nclude that in hadjust. Could you please help me?
Narci4269
Re: Dynamic Conditional Beta
Hi Tom. I am trying to do the calculations using maximize with the code below:
cal(irregular)
all 1734
***** TRANSFORMACIÓN DE DATOS *****
end dofor
end dofor
end dofor
end dofor
end dofor
end dofor
***** Mean Eq *****
vcv(matrix=jj, noprint, centered)
# rdlsp500 rsmb rhml rdlbrent rdlecp
com n = 5
dec vect[series] y(n) u(n)
dec vect[frml] resid(n)
dec series[symm] h uu
set y(1) = rdlsp500
set y(2) = rsmb
set y(3) = rhml
set y(4) = rdlBrent
set y(5) = rdlecp
clear u
linreg(noprint) rdlecp
# constant rdlsp500 rsmb rhml rdlbrent
compute ini=%imax(%regstart(),2),fin=%regend()
linreg(noprint) y(1) ini fin u(1)
# constant
com mk0 = %beta(1)
linreg(noprint) y(2) ini fin u(2)
# constant
com sb0 = %beta(1)
linreg(noprint) y(3) ini fin u(3)
# constant
com hl0 = %beta(1)
linreg(noprint) y(4) ini fin u(4)
# constant
com br0 = %beta(1)
set mkecp = 0.0; set sbecp = 0.0; set hlecp = 0.0; set brecp = 0.0
linreg(noprint) y(5) ini fin u(5)
# constant y(1) mkecp y(2) sbecp y(3) hlecp y(4) brecp
com b0 = %beta(1), b1 = %beta(2), b2 = %beta(3)
com b3 = %beta(4), b4 = %beta(5), b5 = %beta(6)
com b6 = %beta(7), b7 = %beta(8), b8 = %beta(9)
nonlin(parmset=meanparms) mk0 sb0 hl0 br0 b0 b1 b2 b3 b4 b5 b6 b7 b8
frml resid(1) = (y(1)-mk0)
frml resid(2) = (y(2)-sb0)
frml resid(3) = (y(3)-hl0)
frml resid(4) = (y(4)-br0)
frml resid(5) = (y(5)-b0-b1*y(1)-b2*mkecp-b3*y(2)-b4*sbecp-b5*y(3)-b6*hlecp-b7*y(4)-b8*brecp)
gset h  = %zeros(n,n)
vcv(matrix=rr,noprint, centered)
# u
* h will have the sequence of variance estimates
* uu will have the sequence of uu' matrices
* hx and uux are used when extracting elements from h and uu.
declare symm hx(n,n) uux(n,n)
declare vect ux(n)
* This is used to initialize pre-sample variances.
gset h = rr
gset uu = rr
* This is a standard log likelihood formula for any bivariate
* ARCH, GARCH, ARCH-M,... The difference among these will be in
* the definitions of HF and RESID.
declare frml[symm] hf
nonlin(parmset=distrib) nu
frml logl = $
%do(i,1,n,u(i)=resid(i)),$
hx = hf(t) , $
ux = %xt(u,t) , uux = %outerxx(ux),$
h(t) = hx , uu(t) = uux,$
%logtdensity(hx,ux,nu)
com nu = 6
***** DCC *****
dec vect vcv(n) vav(n) vbv(n)
com alpha=0.05, beta=0.90
function hfcccgarch time
type symm hfcccgarch
type integer time
do i=1,n
   compute hx(i,i)=vcv(i)+$
        vbv(i)*h(time-1)(i,i)+vav(i)*uu(time-1)(i,i)
   do j=1,i-1
     compute hx(i,j)=(1-alpha-beta)*jj(i,j)+alpha*uu(time-1)(i,j)+beta*h(time-1)(i,j)
compute hfcccgarch=hx
dec rect dcb(fin,n-1)
do j = ini, fin
   com coeffs =  tr(inv(%xsubmat(h(j),1,4,1,4))*tr(%xsubmat(h(j),5,5,1,4)))
   do i = 1, n-1
      com dcb(j,i) = coeffs(1,i)
set mkecp ini fin = dcb(t,1); set sbecp ini fin = dcb(t,2)
set hlecp ini fin = dcb(t,3); set brecp ini fin = dcb(t,4)
frml hf = hfcccgarch(t)
nonlin(parmset=garchparms) vcv vav vbv alpha beta
compute vcv=%xdiag(rr),vav=%const(0.05),vbv=%const(0.80)
maximize(parmset=meanparms+garchparms+distrib,$
         pmethod=simplex,piters=100,method=bfgs,iters=500) logl ini fin
I don´t know why there is no calculations for dcb arrengement. What could be wrong? Basically the idea is that dcb calculation be included in mean equation for stock returns (see frml resid(5)).
(7.71 MiB) Downloaded 1112 times
What you're looking for is the %PT function, which splits a VECTOR up and puts the components elements of a VECT[SERIES]. You can also use the %SWEEPTOP function to do the projection. The following does the calculation you want for the 3 variable system from GARCHMV.RPF.
open data g10xrate.xls
data(format=xls,org=columns) 1 6237 usxjpn usxfra usxsui
* Examples with the different choices for the MV option
dec vect[series] betas(2)
garch(p=1,q=1,pmethod=simplex,piters=10,hmatrices=hmat,$
   hadjust=%pt(betas,t,%xsubmat(%sweeptop(hmat(t),2),1,2,3,3))) / xjpn xfra xsui
Narci4269
Tom perfect, very useful. It's working!
