Error in group instruction
idomen
Unread post by idomen »
Dear Forum participant
I debugged my code line by line, when I wrote the instruction for a group of equations the following error message showed up:
## SX11. Identifier EQPT1 is Not Recognizable. Incorrect Option Field or Parameter Order?
>>>> eqmt1 eqnl1 eqpt1 <<<<
Is it possible you meant
  EQIT1
  EQMT1
  EQPT2
  EQPT4
  EQAT1
Common errors are
I am stuck ! How can I set up the system of equations and overcome the issue, everything seems correct ?
For my data and code, please, see the attachment
IRFs_aux.RPF
program file
(459 Bytes) Downloaded 1327 times
DATA.xls
data file
(202 KiB) Downloaded 1302 times
idomen
Correct program file
I attach the correct program file. Sorry for any inconvenience!
IRFs_aux.RPF
Program file
(14.97 KiB) Downloaded 1252 times
Re: Error in group instruction
Is there a reason you're running one line at a time? It seems like you skipped over a line when you did that. Select all and run.
idomen
updated RATS code
I removed some bugs and still the code does not produce IRFs. Can you identify the reason why?
idomen
Here is the updated code!
IRFs_aux[2656].RPF
(90.05 KiB) Downloaded 1283 times
Try reducing the number of required draws (such as 500 rather than 5000). The program takes quite a bit of memory and that might be causing a problem.
