Printing Colored Graph in PDF
msrahman
Unread post by msrahman »
I have created a set of colored graphs using spgraph command (First BW and then using the color button turned into colors) . When I print these in PDF, all appear as Black and White. How can I keep the colors?
spgraph(vfields=2,nosamesize,hfields=2,key=bellow,klabels=||"US","UK","JP","CN","GR","FR","IT","SP","BL","NL"||,header="Figure 1. Responses of US variables to a one standard deviation uncertainty shock.")
grparam header 18
grparam key 13
grparm(height=4.5,width=7.0)
grparm(define="line_bw_1=0,0.0,2.0")
grparm(define="line_bw_2=0,0.0,2.0")
grparm(define="line_bw_3=0,0.0,2.0")
grparm(define="line_bw_4=0,0.0,2.0")
grparm(define="line_bw_5=0,0.0,2.0")
grparm(define="line_bw_6=0,0.0,2.0")
grparm(define="line_bw_7=0,0.0,2.0")
grparm(define="line_bw_8=0,0.0,2.0")
grparm(define="line_bw_9=0,0.0,2.0")
grparm(define="line_bw_10=0,0.0,2.0")
graph(style=line,height=100,width=100,header="Real GDP") 10
# RGDPL
# UKRGDPL
# JPRGDPL
# CNRGDPL
# GRRGDPL
# FRRGDPL
# ITRGDPL
# SPRGDPL
# BLRGDPL
# NLRGDPL
graph(style=line,height=100,width=100,header="Industrial Production") 10
# IPI
# UKIPI
# JPIPI
# CNIPI
# GRIPI
# FRIPI
# ITIPI
# SPIPI
# BLIPI
# NLIPI
graph(style=line,height=100,width=100,header="Private Consumption Ex") 10
# PCE
# UKPCE
# JPPCE
# CNPCE
# GRPCE
# FRPCE
# ITPCE
# SPPCE
# BLPCE
# NLPCE
# GCE
# UKGCE
# JPGCE
# CNGCE
# GRGCE
# FRGCE
# ITGCE
# SPGCE
# BLGCE
# NLGCE
Re: Printing Colored Graph in PDF
It sounds like you're handling the colors wrong. Graphs are (by default) color so you should be able to just save the original graph as PDF.
