Change the graphic resolution
wenbei
Unread post by wenbei »
Hi, Is it possible to change the graphic resolution in RATS? I want to save the generated graphics with a high quality, as high as possible. Thanks for your consideration.
Re: Change the graphic resolution
PDF and PostScript are, in effect, infinite resolution—they will adapt to whatever the resolution is on the device on which they are eventually viewed. Other than that, I'm not sure what you mean—it can't show on a display anything more than the resolution of the display.
