GRAPH with different CALENDARs ?
raphael
Unread post by raphael »
Hi all, how can I make a graph of a quaterly series alongside a monthly one (both are growth rates) ? Thanks for your help,
Raphael
Re: GRAPH with different CALENDARs ?
You can do that in separate panes of an SPGRAPH, but they might not align quite correctly. Do you want both graphs to have a "connect-the-dots" look? (standard RATS line graphs). If so, you would need to convert the quarterly growth rate numbers to monthly. The simplest way to do that is actually to use the INTERPOL procedure with MODEL=RW1.
