Style
msrahman
Style
I am trying to make the line in graphs a little thicker using a script (color line.txt). But I do not see any effects on thickness although the program runs well without any error message.
Any advice.
Sincerely,
Sajjadur Rahman
Any advice.
Sincerely,
Sajjadur Rahman
- Combined_One_U.xls
- (389.5 KiB) Downloaded 5648 times
- experiment.rpf
- (6.34 KiB) Downloaded 5459 times
- colorline.txt
- (429 Bytes) Downloaded 5359 times
Re: Style
Your program is using thicklines.txt (which changes the width of B&W lines), not colorline.txt. And your colorline.txt file is designed as a source file, not as a style file and it doesn't put the color codes (the RGB codings of the colors). This is more like what you would want:
and in the program you want
source colorline.txt
not GRPARM with IMPORT. Note, however, that you will probably find the 10 is way too thick.
grparm(define="LINE_COLOR_01=0,000000,10.0") grparm(define="LINE_COLOR_02=0,0000ff,10.0") grparm(define="LINE_COLOR_03=0,00ff00,10.0") grparm(define="LINE_COLOR_04=0,ff0000,10.0") grparm(define="LINE_COLOR_05=0,00ffff,10.0") grparm(define="LINE_COLOR_06=0,ff00ff,10.0") grparm(define="LINE_COLOR_07=0,ffff00,10.0") grparm(define="LINE_COLOR_08=0,808080,10.0") grparm(define="LINE_COLOR_09=0,804000,10.0") grparm(define="LINE_COLOR_10=0,804000,10.0")
msrahman
Re: Style
Thanks for your help.
On another note, I am trying to insert marker (circles) on several colored impulse responses to show the significance (files attached). I successfully did it in the attached black and white pdf file. I added the following in the text file but it is not working.
grparm(define="SYMBOL_COLOR_01=0,FF0000,1")
Any help?
Sincerely,
Sajjadur.
Any help?
Sincerely,
Sajjadur.
- colorline_exp.txt
- (486 Bytes) Downloaded 4948 times
- experiment_one.rpf
- (6.53 KiB) Downloaded 4832 times
- marker.pdf
- (70.56 KiB) Downloaded 4725 times
- Combined_One_U_Experiment.xls
- (391 KiB) Downloaded 4733 times
msrahman
Re: Style
The PDF was done using RATS. I attached the files here.
Any advice how can I place marker on multiple colored lines (files attached before)?
Sincerely,
Sajjadur.
Sincerely,
Sajjadur.
- Fig_Groups.xls
- (32.5 KiB) Downloaded 4415 times
- Fig_1_a.xls
- (39.5 KiB) Downloaded 4193 times
- groups_portfolio_combined.rpf
- (2.84 KiB) Downloaded 4104 times
Re: Style
STYLE=DOTS actually uses the "fill" styles, not the symbol styles (since you have no choice but to use color or grayscale). If you switch your styles on the overlays to 1 and 2 from 5 and 5, the color will do what you want. To get the B&W correct, add
grparm(define="fill_bw_02=0,0.0")
to redefine the style 2 fill to also be full black.
msrahman
Re: Style
Thanks for your help again. One more thing. Is it possible to add any instruction in SPGRAPH to generate just one set of key instead of three set (as in the attached pdf file)?
Sincerely,
Sajjadur.
Sincerely,
Sajjadur.
- Exp_one.pdf
- (46.45 KiB) Downloaded 3926 times
msrahman
Re: Style
Thanks again.
I replaced the yellow with teal (008080). The line is showing as teal but marker remains yellow as in the pdf files. Any thought?
source file:
grparm(define="LINE_COLOR_01=0,000000,2.0")
grparm(define="LINE_COLOR_02=0,0000ff,2.0")
grparm(define="LINE_COLOR_03=0,00ff00,2.0")
grparm(define="LINE_COLOR_04=0,ff0000,2.0")
grparm(define="LINE_COLOR_05=0,00ffff,2.0")
grparm(define="LINE_COLOR_06=0,ff00ff,2.0")
grparm(define="LINE_COLOR_07=0,008080,2.0")
grparm(define="LINE_COLOR_08=0,808080,2.0")
grparm(define="LINE_COLOR_09=0,ff8000,2.0")
grparm(define="LINE_COLOR_10=0,800000,2.0")
source file:
- Experiment.pdf
- (45.82 KiB) Downloaded 3714 times
- (6.6 KiB) Downloaded 3238 times
