Sort strings based on certain values
varcabic
Unread post by varcabic »
Hi all,
I have a seemingly simple problem I cannot solve.
I have a list of countries such as this one:
declare vector[string] labels
compute labels = ||"AT", "BE", "CY", "CZ", "DE", "DK", "EE", "EL", "ES", "FI", "FR", "HR", "HU", "IE", "IT", "LT", "LU", "LV" ,"NL", "PL", "PT", "RO", "SE", "SI", "SK", "UK"||
I would like to sort these strings according to certain values. These values could be a series or a vector[real]. However, I cannot put labels into series and use order instruction. Also, I cannot merge strings with real numbers into an array and use %rankc function.
All I managed to do is rank them in the report, such as this one:
report(action=define,title="Business cycle synchronization in the EU based on synchronicity measure",hlabels=||"","Full sample","","","Post 2007 sample","",""||)
report(atrow=1,atcol=1) "Country" "HP gap" "Average gap" "PC coherent gap" "HP gap" "Average gap" "PC coherent gap"
do i = 1,size
   compute [label] hp  = "sync_hp_"+labels(i)
   compute [label] avg = "sync_avg_"+labels(i)
   compute [label] opt = "sync_opt_"+labels(i)
   sstats(mean) / %s(hp)>>s_hp %s(avg)>>s_avg %s(opt)>>s_opt
   sstats(mean) substart * %s(hp)>>s_hp07 %s(avg)>>s_avg07 %s(opt)>>s_opt07
   report(atrow=i+1,atcol=1) labels(i) s_hp s_avg s_opt s_hp07 s_avg07 s_opt07
report(action=sort,bycol=4,atrow=2)
report(action=show,window="synchronicity")
I would like to sort labels(i) according to s_opt value.
Thanks in advance,
Vladimir
Re: Sort strings based on certain values
If I understand correctly, you want to do something like this:
dec vect[real] values(%size(labels))
compute values=%ran(1.0)
compute sortix=%index(values)
declare vector[string] reordered(%size(labels))
ewise reordered(i)=labels(sortix(i))
The %INDEX function gives you to (smallest to largest) sort index for a VECTOR. (If you want largest to smallest, use %index(-1.0*values)) and you use that to rearrange the strings.
