Error message dfunit
Gilbril
Unread post by Gilbril »
I use the DFUNIT procedure in a routine by default to check the stationarity of the variables . However, I often get the following error message:
## X13. Redundant Restrictions. Using 0 Degrees, not 2
What does this mean and how to turn it off?
Paul
Re: Error message dfunit
That would require a rather serious problem with the data (like all zeros or perhaps some massive outlier that causes calculations to overflow).
