VAR-GARCH BEKK and irf
luxu1983
Unread post by luxu1983 »
dear sir
how can i get the impulse response function from the VAR-Garch bekk model?
thanks
Re: VAR-GARCH BEKK and irf
If you do GARCH(MODEL=mymodel,etc.), you can just do an IMPULSE(MODEL=mymodel,...) instruction. You'd have to pick a covariance matrix or otherwise come up with a set of shocks, since the GARCH model doesn't give you a fixed covariance matrix. But IMPULSE will take care of the dynamics.
luxu1983
TomDoan wrote:If you do GARCH(MODEL=mymodel,etc.), you can just do an IMPULSE(MODEL=mymodel,...) instruction. You'd have to pick a covariance matrix or otherwise come up with a set of shocks, since the GARCH model doesn't give you a fixed covariance matrix. But IMPULSE will take care of the dynamics.
yes i use (model=var) ,my code is
system(model=var1)
variables dlx dly
lags 1
garch(p=1,q=1,model=var1,mv=bekk)
impulse(model=var1,step=20)
i use the impulse instruction but i can not get de irf.
how to modify the code ?
thank you very much TomDoan
luxu1983 wrote: yes i use (model=var) ,my code is
system(model=var1)
variables dlx dly
lags 1
You need a PRINT or a RESULTS option on the IMPULSE.
luxu1983
system(model=var1)
variables dlx dly
lags 1
need a RESULTS option likes "impulse(model=var1,step=20,result=impulses)"?
but the impulses are all zero
TomDoan you can try it
thank you very much
luxu1983 wrote:
system(model=var1)
variables dlx dly
lags 1
thank you very much
That goes back to the previous point - because the GARCH model doesn't estimate a fixed covariance matrix, there isn't any obvious choice for the size of the shocks. So you need a FACTOR or SHOCKS option to feed those in. For instance,
impulse(model=var1,step=20,result=impulses,factor=%identity(2))
will give you unit shocks to each variable.
luxu1983
will give you unit shocks to each variable.[/quote]
you mentioned that the GARCH model doesn't estimate a fixed covariance matrix.
if i want cholesky impulse function, i must need the fixed covariance matrix??
can my code below can get the cholesky impulse function?
garch(p=1,q=1,model=var,mv=bekk,rvector=rr,hmatrices=hh)
*i get the fixed covariance through the standardresid
set standardresid1 = rr(t)(1)/sqrt(hh(t)(1,1))
set standardresid2 = rr(t)(2)/sqrt(hh(t)(2,2))
vcv(matrix=RR)
# standardresid1 standardresid2
impulse(model=var,step=20,result=impulses,decomp=%decomp(RR))
luxu1983 wrote:That goes back to the previous point - because the GARCH model doesn't estimate a fixed covariance matrix, there isn't any obvious choice for the size of the shocks. So you need a FACTOR or SHOCKS option to feed those in. For instance,
vcv(matrix=RR)
[/quote]
Yes. That will give you the IRF for the "average" empirical correlation matrix.
luxu1983
Yes. That will give you the IRF for the "average" empircal correlation matrix.[/quote]
the "average" empircal correlation matrix???
i know this is just Cholesky factorization,and"average" empircal correlation matrix you mentioned above is that meaning?
how can i get the confidence bands?
luxu1983 wrote:Yes. That will give you the IRF for the "average" empircal correlation matrix.
how can i get the confidence bands?[/quote]
Because it's a GARCH model, the H matrix changes from period to period. What you're computing is the correlation matrix of the observed standardized residuals; that's going to average across time periods with different values of H.
What does it mean to get "confidence bands"? This isn't a standard VAR where the covariance matrix is time-invariant.
luxu1983
dear sir
how can i calculate the irf if var garch bekk model includes" M" term
luxu1983 wrote:dear sir
There is no "IRF" for a model like that. For a standard VAR GARCH, the mean model is linear. Once you add an M term, the mean model is non-linear and you can't analyze the response to a shock in isolation.
luxu1983
thank you very much
but how can i get something closer to a IRF
Closer to an IRF than what? Since an abstract IRF doesn't exist, what is it that you are trying to compute? An example of a generalized IRF for a specific type of VAR-GARCH-M is given in
http://www.estima.com/forum/viewtopic.php?f=8&t=1189
The response of the mean with the "M" effect is dependent upon both sign and size of the shock.
luxu1983
how can i do the forcast through different shocks
forcast(model=var,from=100,step=100,shocks=1)
how to set the "shock"
