Box - Cox lambda
tavera
Box - Cox lambda
Unread post by tavera »
Dear all
do you know any procedure or example for calculating the optimal value of the lambda coefficient with a Box-Cox transformation ?
Thanks in advance
Re: Box - Cox lambda
It looks like that was cut out a few versions ago. (I think there used to be an example in one edition of Greene's textbook). That's attached. There is a discussion of the code for the MAXIMIZE approach in the Reference Manual.
boxcox.rpf
(1.53 KiB) Downloaded 1735 times
tavera
Many thanks
