VARLAG—Choice of lag length in a VAR
VARLAG.RPF is an example of lag length selection in a VAR.
This shows several different ways to approach the choice of lag length in a VAR:
  1. It does a formal test of one lag length vs another longer one.
  2. It uses the @VARLagSelect procedure to show an automatic choice mechanism.
  3. It shows the inner workings of the @VARLagSelect procedure in case you need something more flexible than the procedure itself.
Detailed description
Last bumped by TomDoan on Mon Dec 30, 2024 9:37 am.
