Shouldn't GMAUTOFIT.SRC https://estima.com/webhelp/topics/gmaut ... edure.html take into account outliers?
Using AUTOBOX.RPF as an example I get very different residual autocorrelation structure and histogram, using no outliers in BOXJENK vs. OUTLIERS=STANDARD.
* AC_AUTOBOX.RPF
cal(m) 1992:1
open data x12test.xls
data(format=xls,org=columns) 1992:1 2008:7 u11bvs
* transformations
diff u11bvs / du11bvs
set ldata = log(u11bvs)
diff ldata / dldata
prin /
spgraph(hea='u11bvs\\Levels & 1st-Difference',vfi=2,hfi=1)
graph(header="", key=upleft) 1
# u11bvs
# du11bvs
spgraph(hea='ldata\\Levels & 1st-Difference',vfi=2,hfi=1)
# ldata
# dldata
* automated choice for the DIFFS, SDIFFS and CONSTANT options on a BOXJENK instruction
@bjdiff(diffs=2,SDIFFS=1) ldata
* computing and graphing the autocorrelations
* Correlogram of ldata
@bjident(diffs=%%autod,SDIFFS=%%autods) ldata
@gmautofit(diffs=%%autod,sdiffs=%%autods,const=%%autoconst,report) ldata
dec vect[labels] methodlabl(7)
compute methodlabl(1)="const"
compute methodlabl(2)="ar"
compute methodlabl(3)="diffs"
compute methodlabl(4)="ma"
compute methodlabl(5)="sar"
compute methodlabl(6)="sdiffs"
compute methodlabl(7)="sma"
display @@^10 methodlabl
declare vector[integer] parameters(7)
compute parameters(1)=%%autoconst
compute parameters(2)=%%autop
compute parameters(3)=%%autod
compute parameters(4)=%%autoq
compute parameters(5)=%%autops
compute parameters(6)=%%autods
compute parameters(7)=%%autoqs
display @@^10 parameters
boxjenk(diffs=%%autod,sdiffs=%%autods,const=%%autoconst,$
ar=%%autop,sar=%%autops,ma=%%autoq,sma=%%autoqs,define=eq_D) ldata / resids
@regcrits
set fit / = ldata - resids
prin / ldata fit resids
* Actual vs fitted and residuals ARIMA-GM-BIC
spgraph(hea='ldata',vfi=1,hfi=1)
@REGACTFIT
* Residual Plots & Tests
spgraph(hfields=2,vfields=1)
@regcorrs(header="acf plot for residuals",dfc=%narma,number=25,qstats,report,method=YULE) resids
@histogram(header="histogram for residuals with overlay of the normal density",distrib=normal,MAXGRID=60) resids
ar=%%autop,sar=%%autops,ma=%%autoq,sma=%%autoqs,define=eq_D,$
outliers=standard) ldata / resids
@regcrits
@REGACTFIT
Plotting u11bvs and ldata visually there appears to be no outliers.
Yet fitting both BOXJENK models
ar=%%autop,sar=%%autops,ma=%%autoq,sma=%%autoqs,define=eq_D) ldata / resids* 1994:01 0.140773209247
flat residual ACF, non-normal residuals
and using
outliers=standard) ldata / resids* 1994:01 0.096017402284
NOT a flat residual ACF, normal residuals
So isn't GMAUTOFIT identifying the wrong model as OUTLIERS are not being taken into account?
In otherwords, the logic isn't correct in the modelling process.
In general, for any series, the main aim being a flat residual ACF structure, then normal residuals (as bootstrapping can handle non-normality for a simple AR model). Right?
Importantly, at what STAGE in the modelling procedure do I take outliers into account (say, if not using OUTLIERS in BOXJENK but manual pulse dummies)?
thanks,
Amarjit
