write out colunm name
hardmann
Unread post by hardmann »
Dear Tom:
When writing XLSX files, there are dates columns but no column names. How can I add it?
open copy IP_Index.xlsx
copy(dates,format=xlsx,org=columns) 2011:01 2024:12 IP_index  IP_index_sa
Best Regard
Hardmann
Re: write out colunm name
Do you mean no label over the date column?
hardmann
Dear Tom:
Yes it is.
Best Regard
Hardmann
That was added with version 11.
hardmann
Dear Tom:
There is new problem.
Best Regard
Hardmann
That's a known bug that will be fixed soon. However, you can just use the DFORMAT option to set the format for the date column.
hardmann
Dear Tom:
Thanks, It works.
copy(dates,format=xlsx,org=columns,dformat="YYYY:PP")
Best Regard
Hardmann
