problem on version
hardmann
problem on version
Unread post by hardmann »
Dear Tom:
I have programed a couple of the codes of State space with DLM to deal with Extend kalman filter. When I update Winrats from V11.00c to V11.00d, my old codes cannot get right result that is normal under V11.00c.
My codes is not stable, which has different result under different version. I have always been using the Winrats. When V10 releasing, I found my result of old codes from V9.0 is slightly different from V10.
I have an idea that the sub-version can roll-back or select sub-version.
Because I use Winrats frequently and extensively, so I encounter a lot of problem. I know my problem is seldom and stranger. Please Tom give me help and recommandation
Best Regard
Hardmann
Re: problem on version
We haven't made any changes to the DLM instruction since version 10. You would have to post (or send to support@estima.com) a program and data which shows the issue.
