Forecasting a Linear model
Brc
Unread post by Brc »
Hello, I want to forecast the following linear AR model:
DO I=0,20,1
LINREG(DEFINE=FOREQ,NOPRINT) Y 1998:1 2019:12+I
# constant Y{1 3 4 5 7 }
STEPS(NOPRINT) 1 1 2020:1+I
# FOREQ LF 2020:1+I LFE
SET SLFE = LFE**2
STATISTICS(noPRINT) SLFE
COMPUTE RMSE = SQRT(%MEAN)
DISPLAY 'MEAN' %MEAN 'RMSE' RMSE 'I' I
END DO I
However, when I run this code, I got the error message. How can I correct this ?
## SX11. Identifier LF is Not Recognizable. Incorrect Option Field or Parameter Order?
>>>># FOREQ LF <<<<
Is it possible you meant
%L
Common errors are
Thank you for your help.
Re: Forecasting a Linear model
You would need to do a DECLARE SERIES LF LFE before the loop. (Supplementary cards have to be parsed before their context is understood). However, I think you'll find it easier to use the UFORECAST instruction (which is designed specifically for doing forecasts on single linear equations):
https://estima.com/webhelp/topics/ufore ... ction.html
I'm a bit puzzled about what you're trying to do with the forecast errors. The first time through the loop, you're taking the RMSE of just one forecast error. Is that what you want?
Also:
SET SLFE = LFE**2
can be replaced by the use of the SSTATS instruction:
https://estima.com/webhelp/topics/sstat ... ction.html
sstats(mean) / lfe^2>>mse
compute rmse=sqrt(rmse)
Brc
Thank you for your helps.
I have working on one-step ahead forecast for univariate linear model estimation.
According to your instruction, I rewrite my code as follows:
Is this code correct?
DO I=0,64,1
LINREG(DEFINE=FOREQ,NOPRINT) Y 2008:1 2019:12+I
# constant Y{1 2 3 4 5}
UFORECAST(EQUATION=FOREQ,STATIC, stderrs=LFE) Linforecast 2020:1 2025:05
SET SLFE = LFE**2
END DO I
You want the ERRORS option on the UFORECAST, not STDERRS.
