DECO GARCH error
econonick
DECO GARCH error
Unread post by econonick »
I added the following code to the original DECO model code provided in RATS to compute the conditional covariance(Ht).
dec series[symm] Hcov
compute tstart = %regstart()
do t = tstart, %regend()
   dec vect std(n)
   do i=1,n
      compute std(i) = vol(i)(t)
   * DECO H(t): variance-covariance
   compute Hcov(t) = %mqform(%cvtocorr(q(t)), %diag(std))
end do t
However, when I run this code, I get the following error:
The Error Occurred At Location 130, Line 10 of loop/block
Could you please explain the reason why this error occurs?
I have attached the code and the file.
g10xrate.xls
(1.2 MiB) Downloaded 1122 times
garchdeco_Ht.RPF
(2.48 KiB) Downloaded 896 times
Re: DECO GARCH error
You can do the whole extra calculation with the single instruction:
gset hcov %regstart() %regend() = %mqform(%cvtocorr(q),%diag(%xt(vol,t)))
The problem was with trying to do a COMPUTE on a single element of HCOV without the range of the SERIES[SYMM] ever having been set. GSET takes care of that.
(You could fix the original code by adding
gset hcov %regstart() %regend() = %zeros(n,n)
which initializes the range of HCOV for the later COMPUTE instructions)
