About the KEYLABEL option in GRAPH command
Jennylai
Unread post by Jennylai »
Hi, may I ask a question about the KEYLABEL option in GRAPH command?
My code is as follows:
declare vect[string] grakey
compute grakey = ||'BMS','S&T','EMS','ACT'||
graph(header='predicted values of BF and true out of sample BF',patterns,keylabel=grakey,key=below) 4
# ytf_ne / 3
# ytfs / 5
# ytxfs / 6
# ytafs / 1
I want to let the key to show as this: BMS for YTF_NE, S&T for YTFS, EMS for YTXFS, and ACT for YTAFS. However, the code report error like this:
## SX22. Expected Type INTEGER, Got VECTOR(STRING) Instead
>>>>ns,keylabel=grakey,<<<<
How to fix the problem?
Thank you very much!
Re: About the KEYLABEL option in GRAPH command
Jennylai wrote:Hi, may I ask a question about the KEYLABEL option in GRAPH command?
# ytf_ne / 3
# ytfs / 5
# ytxfs / 6
# ytafs / 1
The option is KLABEL, not KEYLABEL. Only the first three characters are significant in an option name, so we can't have both KEYLABEL and KEY options.
