creating FRML's
John_Val
creating FRML's
I wrote the following program:
dec vec h1(3)
dec vec h2(3)
nonlin h1 h2
frml exq = 0
do i = 1,3
frml exq = exq + h2(i)/(1+exp(-(h1(i)*libm{i})))
com h1 = %ran(5)
com h2 = %ran(5)
nlls(frml=exq) libm
## NL1. FRML References More Than 20 Deep. Do You Have a Self-referencing FRML?
where libm is the series. What is the error message related to? Is the frml created through the do loop valid? I know I can just write out the model without using the loop, but I want to know how to loop over the frml command to creat long frmls with many parameters, without writing the model in one line.
dec vec h1(3)
dec vec h2(3)
nonlin h1 h2
frml exq = 0
do i = 1,3
com h1 = %ran(5)
com h2 = %ran(5)
nlls(frml=exq) libm
Re: creating FRML's
FRML's don't work that way. While it's possible to define a single FRML using %DO, it's simpler to write a function instead:
You have to pass the value of "T" to the function and use subscripts on the series reference in it, since it can't do the {...} notation for lags.
function exqf time
compute exqf=0.0
do i=1,3
compute exqf = exqf + h2(i)/(1+exp(-(h1(i)*libm(time-i))))
end exqf
nlls(frml=exqf(t)) libm -
John_Val
Re: creating FRML's
I am still using version 5 and it does not have user defined functions. Is there an alternative way to do the above in version 5.
Re: creating FRML's
The simplest is to write the three terms out. If you want to maintain the flexibility to change n, use %DO.
John_Val
Re: creating FRML's
I tried setting it up by following the example that was done with the Markov-Switching model when setting up the likliehood function using %( ) and %do( ).
When I run the code below I get no error message but the program breaks down.
nonlin h1 h2
frml XX = %(exq=0.0,%do(i,1,3,exq + h2(i)/(1+exp(-(h1(i)*libm{i})))),exq)
com h1 = %ran(5)
com h2 = %ran(5)
nlls(frml=XX) libm
nonlin h1 h2
com h1 = %ran(5)
com h2 = %ran(5)
nlls(frml=XX) libm
Re: creating FRML's
That needs to beJohn_Val wrote:I tried setting it up by following the example that was done with the Markov-Switching model when setting up the likliehood function using %( ) and %do( ).
nonlin h1 h2
com h1 = %ran(5)
com h2 = %ran(5)
nlls(frml=XX) libm
frml XX = %(exq=0.0,%do(i,1,3,exq = exq + h2(i)/(1+exp(-(h1(i)*libm{i})))),exq)
