PhillipsHannan—Multivariate Hannan Efficient
This is an updated version of a procedure originally written by Rob Trevor to do Hannan efficient with multiple RHS lag structures; particularly for use in Phillips' estimator for the cointegrating matrix with arbitrary multivariate correlation structure.
* @PhillipsHannan( options )  B START END
* #<supp. card> list of (P) endogenous variables
* #<supp. card> list of (Q) predetermined variables
* This procedure uses Hannan's Efficient Estimator to: estimate a set of linear
* equations with stationary errors; and test linear restrictions on the parameter
* matrix.
* Parameters:
*   B      = Initial estimate of coefficient matrix (PxQ)
*   START  = First observation
*   END    = Last observation
* Options:
*   PHILLIPS/[NOPHILLIPS] Whether doing Phillips' estimation of cointegrating matrix
*   BANDSPEC/[NOBANDSPEC] (Valid only if PHILLIPS) Whether to calculate estimates
*      using Band Spectral technique instead of Hannan
*   TEST/[NOTEST] Whether testing a set of linear restrictions H*BVEC=R where
*      where BVEC is a column vector which contains the stacked rows of the matrix B                                               *
*   MEANCORR/[NOMEANCORR] Whether to remove a constant term
*   SEASONAL/[NOSEASONAL] Whether to remove seasonal terms
*   TREND/[NOTREND] Whether to remove a linear time trend
*   ORDINATE = Number of ordinates [depends upon length, seasonal]
*   WINDOW = [FLAT]/TENT
*   WIDTH = Window width [depends upon ordinates]
*   ITER = Number of iterations to update initial estimate [1]
*   OLS/[NOOLS] Whether iteration 1 estimates are constrained to be the
*      the OLS estimates
*   H  = A SxPQ array of S linear restrictions (H*BVEC=R) on the
*      vector of estimated coefficients BVEC (used with TEST option)
*   R  = A Sx1 vector of linear restrictions (H*BVEC=R) on the
*  Output:  (GLOBAL arrays)
*     BVEC   = Coefficient matrix stacked into a vector (P*Qx1)
*     VVAR   = Covariance matrix of the parameter estimates, corresponding
*              to the vectorised array BVEC
*  Version 1.0
*  Copyright (c) Robert G Trevor August 1990, 1992
*  Trevor and Associates ACN 065 479 549
*  Email: rtrevor@alumni.princeton.edu
*  Reference:  Phillips, P.C.B. (1991).  "Error Correction and Long Run
*              Equilibria in Continuous Time." Econometrica, Vol. 59, pp. 967-980.
*  Used in:    Hall, V.B. and R.G. Trevor (1992).  "Long Run Equilibrium
*              Estimation And Inference: A Non-Parametric Application."  In
*              P.C.B. Phillips (ed), Models, Methods and Applications of
*              Econometrics: Essays in Honour of A.R. Bergstrom. Basil
*              Blackwell (1992).
*  Revision Schedule:
*   07/2005 Updated by Tom Doan, Estima, to version 6. Minor change to syntax
*           (converted H and R to options)
*   04/2008 Renamed PhillipsHannan to match file name
proc PhillipsHannan  b start end
type integer start end
type rectangular *b
option switch   phillips 0
option switch   bandspec 0
option switch   test     0
option switch   meancorr 0
option switch   seasonal 0
option switch   trend    0
option switch   ols      0
option int      ordinate
option int      width
option int      iter     1
option choice   window   1 flat tent
option rect     h
option vect     r
local index serlisty serlistx serlistz
local integer pp p q s nrow ncol startm endm startl endl
local integer nobs counter m k
local real scalefac delta x2 signif
local lvector serlabsy serlabsx
local rectangular cyx qyx trb cinvq u v rhs e
local symmetric  cyy qyy cee qee w vcor veqn
local rect cxx qxx
local vector omega beqn
local integer dobandspec
local integer i j jj iloop slead nords
local vect[series] d
local rect[complex] fyy fxx fyx fee feeinv
local rect[complex] cxupdate
declare symmetric vvar
declare vector bvec
local series seasons time
local equation equation
if phillips==0.and.bandspec==1
   dis "*** WARNING BandSpec switch ignored when Phillips switch is off ***"
   compute dobandspec=0
else
   compute dobandspec=bandspec
* Read in series names and calc number of series
enter(varying) serlisty
enter(varying) serlistx
inquire(matrix=serlisty) p
inquire(matrix=serlistx) q
* Set number of LHS variables
if phillips==1
   compute pp=p+q
else
   compute pp=p
* Check dimensions of coefficient matrix
compute nrow=%rows(b),ncol=%cols(b)
if nrow<>p.or.ncol<>q
   dis "B must have as many rows as endogenous variables and"
   dis "  as many columns as predetermined variables"
   return
* Check dimensions of restriction matrices
if test==1
   * Check dimensions of R
   compute s=%rows(r),ncol=%cols(r)
   if ncol>1
      dis "R must be a vector"
      return
   * Check dimensions of H
   compute nrow=%rows(h),ncol=%cols(h)
   if ncol<>p*q
      dis "H must have as many columns as the number of parameters (P*Q)"
      return
   if nrow<>s
      dis "H and R must have the same number of rows"
      return
else
   * Set up test that all coefficients are zero
   compute S=P*Q
* Store series labels
dimension serlabsy(p) serlabsx(q)
ewise serlabsy(i)=%l(serlisty(i))
ewise serlabsx(i)=%l(serlistx(i))
* Calculate start and end for input variables
inquire(reglist) startm endm
# serlisty serlistx
* Adjust for lags
if phillips==1
   compute startm=startm+1
if .not.%defined(start).and..not.%defined(end)
   compute startl=startm
   compute endl=endm
else
   if start<startm.or.end>endm
      dis "ERROR:  Not all series are defined over range"  START END
      dis "        Common range is                      "  STARTM ENDM
      return
   compute endl=end
* Define length of complex series
if %defined(ordinate)
   compute nords=ordinate
else
   compute nords=%freqsize(endl-startl+1)
* Set up data series
dim d(pp+q)
* Put Y series into 1 to PP
* Put X series into PP+1 to PP+Q
* set up deterministic components
if seasonal==1
   seasonal seasons
   compute slead = (1:1 - 0:1) - 2    ; * calculate seasonal frequency - 2
   enter(varying) serlistz
   # constant  seasons{-slead to 0}
else if meancorr==1
   # constant
else
   dimension serlistz(0)
if trend==1
   set time = t
   # serlistz time
* Regress variables against deterministic components. Stuff
* residuals into slots in "d"
do i=1,p
   linreg(noprint) serlisty(i) startl endl d(i)
   # serlistz
   label d(i)
   # "#"+serlabsy(i)
if phillips==1
   do i=1,q
      linreg(noprint) serlistx(i) (startl-1) endl d(p+i)
      # serlistz
      set d(pp+i) startl endl = d(p+i){1}
      label d(pp+i)
      # "#l"+serlabsx(i)
      difference d(p+i) startl endl
else
   do i=1,q
      linreg(noprint) serlistx(i) startl endl d(pp+i)
      # serlistz
      label d(pp+i)
      # "#"+serlabsx(i)
* Set up complex series
* FFT Y  are in     1            to           PP
*     X             PP+1                      PP+Q
* Periodograms YY:  PP+Q+1                    PP+Q+(PP*PP)
*              YX:  PP+Q+.5*PP(PP+1)+1        PP+Q+.5*PP(PP+1)+(PP*Q)
*              XX:  PP+Q+.5*PP(PP+1)+(PP*Q)+1 PP+Q+.5*PP(PP+1)+(PP*Q)+.5*Q(Q+1)
compute counter = pp + q + pp*(pp+1)/2 + pp*q + q*(q+1)/2 + 1
frequency counter nords
* Convert time domain data to frequency domain
rtoc startl endl 1
# d
# 1 to (pp+q)
* Take Fast Fourier Transforms
do i=1,(pp+q)
   fft i
* Calculate cross periodograms
compute nobs=endl-startl+1
compute scalefac = 1./(2.*%pi*nobs)   ; * RATS doesn't divide fft by sqrt(2*pi*t)
compute counter=pp+q
do i=1,pp
   do j=1,i
      compute counter = counter + 1
      cmult(scale=scalefac) i j / counter
do i=1,pp
   do j=(pp+1),(pp+q)
do i=(pp+1),(pp+q)
   do j=(pp+1),i
if counter<>pp+q+pp*(pp+1)/2+pp*q+q*(q+1)/2
   dis "error:  count error in loop:  location 1"
   return
* Smooth cross periodograms
* This shifts series in by (PP+Q)
* Spectrums of YY are   1                      .5*PP(PP+1)
*              YX       .5*PP(PP+1)+1          .5*PP(PP+1)+(PP*Q)
*              XX       .5*PP(PP+1)+(PP*Q)+1   .5*PP(PP+1)+(PP*Q)+.5*Q(Q+1)
* Set up mask for frequency zero to over-ride default
cset (counter+1) = 1.
* Smooth
do i=(pp+q+1),counter
   window(type=window,width=width,mask=(counter+1)) i / (i-(pp+q))
   cmult (i-(pp+q)) (counter+1) / (i-(pp+q))
* Set up complex arrays
compute m = fix(nords/2.)
if phillips==1
   dimension e(pp,p)
   ewise e(i,j)=(i==j)
* For each iteration calculate estimates
do iloop=1,iter
   dimension cyy(pp,pp) qyy(pp,pp) cyx(pp,q) qyx(pp,q) cxx(q,q) qxx(q,q)
   dimension cee(pp,pp) qee(pp,pp) rhs(p,q) w(p*q,p*q)
   dimension fyy(pp,pp) fyx(pp,q) fxx(q,q) fee(pp,pp)
   dimension u(pp,pp) v(pp,pp)
   compute rhs = %const(0.0)
   compute w   = %const(0.0)
   do k=0,m
      if (dobandspec==1.and.k<>0).and.(ols==0.or.iloop<>1)
         break ;* Exit loop to get Band Spectral estimates
      * For each frequency 0<=w<=Pi
      compute counter=0
      * Set up Fyy = 2.0*(Cyy -iQyy)
      do i=1,pp
         do j=1,i
            compute counter=counter+1
            compute fyy(j,i) = 2*%z(k+1,counter)
            compute fyy(i,j) = %conjg(fyy(j,i))
      * Set up Fyx = 2.0*(Cyx -iQyx)
      do i=1,pp
         do j=1,q
            compute fyx(i,j) = 2.0*%conjg(%z(k+1,counter))
      * Set up Fxx = 2.0*(Cxx -iQxx)
      do i=1,q
         do j=1,i
            compute fxx(j,i) = 2.0*%z(k+1,counter)
            compute fxx(i,j) = %conjg(fxx(j,i))
      if counter<>pp*(pp+1)/2+pp*q+q*(q+1)/2
         dis "ERROR:  COUNT ERROR IN LOOP:  LOCATION 2 -" K
         return
      * Calculate Fee = .5*(Cee -iQee)
      if (ols==0.or.iloop<>1)
         if phillips==1
            compute trb = tr(e*b)
            compute fee = fyy + e*b*fxx*trb - fyx*trb - e*b*%cxadj(fyx)
         else
            compute trb = tr(b)
            compute fee = fyy + b*fxx*trb - fyx*trb - b*%cxadj(fyx)
      else
         * To get OLS estimates ignore spectrum of residuals - assume flat
         ewise fee(i,j)=%if(i==j,1./%pi,0.0)
      compute feeinv=%cxinv(fee)
      if k==0.or.k==m
         if dobandspec==0.or.(ols==1.and.iloop==1)
            compute delta=0.5/float(m)
         else
            compute delta=1.0
      else
         compute delta=1.0/float(m)
      if phillips==1
         * Replace Hannan's U and V by E'U and E'V
         compute feeinv=tr(e)*feeinv
      compute cxupdate=feeinv*fyx
      ewise rhs(i,j)=rhs(i,j)+delta*%real(cxupdate(i,j))
      if phillips==1
         * Replace Hannan's U and V by E'UE and E'VE
         compute feeinv = feeinv*e
      ewise u(i,j)=%real(feeinv(i,j))
      ewise v(i,j)=%imag(feeinv(i,j))
      ewise cxx(i,j)=%real(fxx(i,j))
      ewise qxx(i,j)=%imag(fxx(i,j))
      compute w = w + delta*(%kroneker(u,cxx) - %kroneker(v,qxx))
   end do k
   release cyy qyy cyx qyx cxx qxx cee qee trb cinvq u v
   * Set OMEGA to the stacked rows of RHS
   dimension omega(p*q)
   compute counter=0
   do i=1,p
      do j=1,q
         compute omega(counter) = rhs(i,j)
   if counter<>(p*q)
      dis "ERROR:  COUNT ERROR IN LOOP:  LOCATION 3"
      return
   release rhs
   compute vvar = inv(w)
   compute bvec = vvar*omega
   compute vvar = vvar/float(nobs)
   if dobandspec==1
      * Degrees of Freedom scale factor
      compute vvar = (2.*m)*vvar
   release omega w
   * Update B matrix
   compute counter=0
   do i=1,p
      do j=1,q
         compute b(i,j) = bvec(counter)
   if counter<>(p*q)
      dis "ERROR:  COUNT ERROR IN LOOP:  LOCATION 4"
      return
   * Calculate correlations across parameter estimates
   dimension vcor(p*q,p*q)
   do i=1,p*q
      do j=1,i
         compute vcor(i,j) = vvar(i,j)/sqrt(vvar(i,i)*vvar(j,j))
   if iloop==1
      dis
      if phillips==1
         dis "                     PHILLIPS COINTEGRATION ESTIMATION"
      if dobandspec==0
         dis "                         HANNAN EFFICIENT ESTIMATES"
      else
         dis "                           BAND SPECTRAL ESTIMATES"
      dis
      dis "Period:" %datelabel(startl) %datelabel(endl) "=>" #### (ENDL-STARTL+1) "obs"
      dis
      dis "Endogenous variables are:"
      write(noskip) serlabsy
      dis
      dis "Predetermined variables are:"
      write(noskip) serlabsx
      dis
   dis "Iteration:" ILOOP
   dis "Parameter estimates: "
   write(noskip) b
   dis
   dis "Correlation matrix of parameter vector"
   write(noskip) vcor
   dis
   release vcor
end do iloop
release e
* Calculate test statistic and significance level
if test==1
   compute x2 = %qform(inv(h*(vvar*(tr(h)))),r-h*bvec)
else
   compute x2 = %qform(inv(vvar),bvec)
cdf(noprint) chisquared x2 s
compute signif=%signif
if test==1
   dis "WALD TEST OF RESTRICTIONS H*BVEC=R"
   dis
   dis "H"
   write(noskip) h
   dis
   dis "R"
   write(noskip) r
   dis
else
   dis "WALD TEST OF RESTRICTION THAT ALL PARAMETERS ARE ZERO"
   dis
dis "------------------- "
dis "Wald Stat | P-Value "
dis   ######.## X2  "|"  #.#### SIGNIF
dis
* Write out estimates equation by equation
dimension beqn(q) veqn(q,q)
* Change SERLISTY to transformed variables
# d(1)
do i=2,p
   # serlisty d(i)
* Change SERLISTX to transformed variables
# d(pp+1)
do j=2,q
   # serlistx d(pp+j)
equation(noconstant) equation serlisty(1)
# serlistx
* For each equation set up param vector and cov matrix
do i=1,p
   do j=1,q
      compute beqn(j) = bvec((q*(i-1))+j)
      do jj=1,j
         compute veqn(j,jj) = vvar((q*(i-1))+j,(q*(i-1))+jj)
      end do jj
   dis
   dis
   if phillips==1
   if (ols==1.and.iter==1)
      * Turn on residual variance calculation
      dis "                               OLS ESTIMATES"
      linreg(create,coeff=beqn,covmat=veqn,scale,equ=equation) $
   else
      if dobandspec==0
      else
      linreg(create,coeff=beqn,covmat=veqn,noscale,equ=equation) $
release serlisty serlistx serlistz serlabsy serlabsx
release beqn veqn
Future
Re: PhillipsHannan - Multivariate Hannan Efficient
Unread post by Future »
Hi, Tom!
I'm learning @PhillipsHannan, and would like to ask a few questions:
1. I can't find example about"@ PhillipsHannan (options) B START END". How to define and use B? I would like to get some examples help to learn it.
2. Band Spectrum Regression aren’t even taught today,have been replaced by modernized versions? or have some disadvantage and no longer suitable for use?
3. Could you give me some example of Band Spectral Tests of Symmetric Price Transmission for reference?
Thank you very much!
It's not always clear why certain ideas and techniques go out of fashion, but I'm not sure band spectrum regression ever really was in fashion which is why there are so few examples of it. The closest thing to a replacement has been the widespread use of band pass filters (such as HP and Christiano-Fitzgerald) on the individual data series rather than on the regression.
