Convert monthly data to daily
This interpolates a monthly series to (business) day data. Note that you have to read the data into a DAILY calendar, and thus need to be reading from a file format with dates. The original monthly value (this is CPI less food and energy) will be repeated for each day within the month. In order to make the state space model work, you need to pick just one time period within the month to represent the observed data. Here, we take the weekday closest to the 15th since that corresponds roughly to the timing of the (sampling done for the) CPI. The %if(smpl,logcpi,%na) turns into NA all other data points within the month.
Since the state space model has a zero measurement error (no SV option), the smoothed series will hit the exact values at those chosen points within the month.
* Creates a daily series by interpolating a monthly series
calendar(daily) 1999:1:1
open data cpifens.xls
data(format=xls,org=columns) * 2009:12:31 cpilfens
set logcpi = log(cpilfens)
* Find the weekday closest to the 15th
set smpl = %day(t)==%closestweekday(%year(t),%month(t),15)
* RW-AR1 state space model estimated in logs
nonlin rho
dec frml[rect] af
frml af = ||1.0+rho,-rho|1.0,0.0||
compute f=||1.0|0.0||
compute c=||1.0|0.0||
compute rho=0.0
dlm(a=af,c=c,f=f,y=%if(smpl,logcpi,%na),sw=1.0,var=conc,$
  g=||1.0,-1.0||,method=gauss,type=smooth) / xstates
* Exp interpolated data back. Create a series with just the monthly
* value used. Graph the interpolated data (using a light gray) with
* symbols at the observed data points.
set interp  = exp(xstates(t)(1))
set monthly = %if(smpl,cpilfens,%na)
graph(overlay=symbols,ovsame) 2
# interp / 8
# monthly
Data file:
cpifens.xls
(23.35 KiB) Downloaded 1993 times
ivory4
Re: Convert monthly data to daily
Unread post by ivory4 »
How g is chosen?
ivory4 wrote:How g is chosen?
You can now use PRESAMPLE=ERGODIC rather than using G. The state-space model has two states with one unit root so ||1.0,-1.0|| transforms the states to the stationary submodel.
