robust option
luxu1983
robust option
Unread post by luxu1983 »
dear Tom
when i do garch estimation
Is QMLE estimator not efficiency when the the distribution is not normal ?
that means i should use the "robust" option?
thank you very much
Re: robust option
If the residuals aren't Normal, but you use the standard GARCH, then, yes, you are getting a QMLE, and an asymptotically valid covariance matrix for the coefficients is computed with the ROBUST option.
