Use of LSDVC (Kiviet bias correction)
This is an example of the use of the LSDVC procedure (see http://www.estima.com/forum/viewtopic.php?f=7&t=617) for estimating dynamic panel data models.
* Example of estimation of a dynamic panel data model with LSDV
* corrected for bias.
compute n=94
cal(panelobs=6)
all 94//6
open data penngrow.txt
data(org=columns) / indiv year y x
* Least squares; doesn't allow for individual effects.
linreg y
# constant y{1} x
* Fixed effects. Severe bias with so few data points
preg(method=fixed) y
# y{1} x
* Anderson-Hsiao. Consistent, but has very low efficiency.
@lsdvc(method=ah) y
# x
* LSDV with Kiviet 3-term correction
@lsdvc(method=k3) y
# x
Data file
penngrow.txt
(14.97 KiB) Downloaded 1767 times
