bivariate common cycle test a la Engle-Kozicki(1993)
rylsnat
Unread post by rylsnat »
Has anyone experimented with the bivariate common cycles tests as proposed in Engle-Kozicki (1993) and Engle-Vahid (1993) papers? I am having problem understanding the Engle-Kozicki procedure for the common feature test since it links estimation of the bivariate VAR(1) in conjunction with the 2SLS and LIML estimations. I would appreciate any help on this issue, including any sample code.
This would show the three ways to compute this for the pair jpngnp and gbrgdp. The test statistics are the LIML specification test for the LIML estimator and the J-statistics for the two directions of the IV estimates.
instruments constant jpngnp{1} gbrgdp{1}
@liml jpngnp
# constant gbrgdp
linreg(inst) jpngnp
# constant gbrgdp
linreg(inst) gbrgdp
# constant jpngnp
nightwalk
on the Engle and Kozicki (1993) common features
Unread post by nightwalk »
I have isolated the series with significant ARCH effects and i want to estimate now the bivariate Engle and Kozicki common features test, which is performed (to the best of my knowledge) by two-stage least squares and the use of instrumental variables.
Can you give me such a code in RATS by explaining each stage? I think that the code you have provided in the forum is not the suitable one.
Warm regards
