Forecasting with STAR model
This is an example of forecasting with a STAR model (specifically an LSTAR model). It is based upon the model from the Terasvirta JASA 1994 replication, but with a simpler model. Because a STAR model is non-linear, the forecast, in the sense of the mean of the process, can't be computed analytically. Instead, it is calculated by averaging across simulated values. The non-stochastic forecast is also an object of interest, called the "eventual forecast function". This shows the way that the process cycles in the absence of shocks.
Program:
lynxforecast.rpf
(2.62 KiB) Downloaded 1388 times
Data:
LYNX.DAT
(663 Bytes) Downloaded 1209 times
Graph:
lynxforecast.pdf
(3.77 KiB) Downloaded 1049 times
