Non Linear Estimation - AR(2) process
protoss
Unread post by protoss »
Dear User,
I have a problem: I'd like to estimate the PHI-coefficients of an AR(2) process using a non linear estimation. How can I tell RATS to do so?
Thank you very much in advance
protoss
Re: Non Linear Estimation - AR(2) process
The options for this are described in section 5.5 (Serial Correlation) in the User's Guide. This example does AR(2) regressions (after some examples of AR(1)) done several different ways.
Program file:
grnp649.rpf
(2.58 KiB) Downloaded 1232 times
Data file:
gasolinemarket.xls
(10.61 KiB) Downloaded 1307 times
