IPSHIN—Im-Pesaran-Shin Panel Unit Root
Post by TomDoan »
@IPShin implements tests from Im, Pesaran and Shin, "Testing for Unit Roots in Heterogeneous Panels", J. of Econometrics, 2003, vol 115, pp 53-74. This aggregates the ADF test statistics computed separately across individuals. Under the null, the average ADF statistic has a Normal limiting distribution as N->infinity.
Detailed description
Reason: Switch to description from HTML help
tflavin71
Re: IPSHIN - Im-Pesaran-Shin Panel Unit Root
Post by tflavin71 »
I am trying to run this procedure in WinRATS 8.0 and keep getting the following error message
## OP10. Instruction PSTATS Requires Option BLOCK
The Error Occurred At Location 489, Line 190 of IPSHIN
I can't see where I am going wrong - any help appreciated.
Post by TomDoan »
Do you have a panel data CALENDAR? If you don't, it has no idea how to separate the data into individuals.
tflavin71
Post by tflavin71 »
Thanks for pointing that out.. the proper Calendar instruction works but I have one further problem. Now the procedure runs the test on one series, even though I want it to run on the whole panel. The data reads in properly
Here is my instruction and output
OPEN DATA "G:\PPP\CIPS.csv"
CALENDAR(PANELOBS=588,M) 1957:1
ALL 10//588
DATA(FORMAT=PRN,nolabels,ORG=COLUMNS) 1//1957:1 1//2005:12 AUSTRIA BELGIUM FINLAND FRANCE GREECE IRELAND $
ITALY NETHERLANDS PORTUGAL SPAIN
@ipshin AUSTRIA BELGIUM FINLAND FRANCE GREECE IRELAND $
Output:
Im-Pesaran-Shin Unit Root Test: Series AUSTRIA
Test has large N on large T asymptotics
Null is Unit Root. Alternative is rho(i)<>1 for some i
Individual Specific Components: Constant
N 1
T 1
P 0
Statistic Signif Level
Z tbar 1.150657 0.875063
Z ttildebar NA NA
TBar 0.000000
T-tilde-bar NA
1% CV -3.790000
5% CV -2.760000
10% CV -2.380000
Thanks in advance..
Post by TomDoan »
You have to PFORM the separate time series into a panel data set first.
CALENDAR(M) 1957:1
DATA(FORMAT=PRN,nolabels,ORG=COLUMNS) 1957:1 2005:12 AUSTRIA BELGIUM FINLAND FRANCE GREECE IRELAND $
PFORM cips
# AUSTRIA BELGIUM FINLAND FRANCE GREECE IRELAND $
* Reset the CALENDAR to a panel date schem
cal(panelobs=2005:12,m) 1957:1
all 10//2005:12
@ipshin cips
celineboulenger13
Post by celineboulenger13 »
Hi, I am working on testing for unit roots in a multivariate panel but when I use @ipshin for gdp, the results look different than when I do it for the variable re.
Here are the 2 outputs/inputs
@ipshin gdp
Im-Pesaran-Shin Unit Root Test: Series GDP
N 23
T 22
P 0
Z tbar 4.317106 0.999992
Z ttildebar 4.475388 0.999996
TBar -0.710339
T-tilde-bar -0.694758
1% CV -1.940000
5% CV -1.820000
10% CV -1.750000
@ipshin re
Im-Pesaran-Shin Unit Root Test: Series RE
N 23
T 21 to 22
P 0
Z tbar 6.731118 1.000000
Z ttildebar 6.318091 1.000000
This is a problem since I need to report the tstats. I don't know why it doesn't show for RE.
Thank you for your help!
Post by TomDoan »
The t-statistic is only available when the data set is balanced. Yours isn't---at least one of the individuals is missing a data point for RE.
It looks like you're testing your raw data. Shouldn't you do using the logs instead?
celineboulenger13
I did have one missing value but I fixed that but I still cannot get the t-stats reported when using the series re (these are in logs).
@ipshin(lags=5) re
N 23
T 17
P 5
Z tbar 5.653283 1.000000
Z ttildebar 5.647141 1.000000
Any other reason why it could not give me tstats? thanks!
celineboulenger13
Is there any way to include the max amount of lags and also get tstats? I am trying to report both but it seems that when lags are included, the tstats are not reported. THanks !!!
@ipshin(det=trend,crit=aic) re
Individual Specific Components: Constant + Trend
N 23
T 22
Avg P 0.000000 chosen from 0 by AIC
Z tbar -0.125701 0.449984
Z ttildebar 2.259853 0.988085
TBar -2.189132
T-tilde-bar -1.769112
1% CV -2.580000
5% CV -2.460000
10% CV -2.400000
@ipshin(crit=aic,lags=5) re
N 23
T 17 to 22
Avg P 1.347826 chosen from 5 by AIC
Z tbar 6.585091 1.000000
Z ttildebar 6.217889 1.000000
Post by TomDoan »
The t-stats are only available in very, very, controlled situations (balanced sample, no augmenting lags). The main test statistic is the average Z.
Yes, @IPSHIN has options for choosing the number of lags, which, as is typical of panel UR tests, does a separate analysis for each individual. See the detailed description link at the first page.
However, from the look of it, this series isn't a candidate for a unit root test. It has to be really explosive to generate a test statistic like that (probably not surprising given what it is).
Last bumped by TomDoan on Tue Aug 21, 2018 4:35 pm.
