nokbox option and .EPS graphs
MMandler
Unread post by MMandler »
I have created a number of graphs using the NOKBOX option to suppress the boxes around the key. The graphs look fine in RATS and if printed directly. However, if I save them as .EPS using the "Save As" Command in the "File" menu the box
around the keys is visible again in the postscript file. Does anybody know how to really get rid of the key box?
Martin
Site Admin
Re: nokbox option and .EPS graphs
Unread post by moderator »
Martin,
What version of RATS are you using? You can do Help-About RATS to check the exact release number.
Tom Maycock
MMandler
Tom,
I am using version 7.1.
Martin
The PostScript kbox problem was corrected with 7.2.
MMandler
Martin
