Using Maximize with GARCH model
ivory4
Unread post by ivory4 »
UG---GARCHUV
How to display a formula ?
Questions are in the brackets included in the code.
Thanks in advance.
* Same model estimated using MAXIMIZE
linreg dlogdm
# constant dlogdm{1}
frml(lastreg,vector=beta) meanf
nonlin(parmset=meanparms) beta  (Without followed by a MAXIMIZE NLLS or DLM, this is [i]only[/i] for assigning parameter values (BETA(1) BETA(2) here) to MEANPARMS defined in PARMSET?)
set uu = %seesq
set h  = %seesq
set u  = 0.0
nonlin(parmset=garchparms) c a b
compute c=%seesq,a=.05,b=.05
frml varf = c+a*uu{1}+b*h{1}
frml logl = (u=dlogdm-meanf),(uu(t)=u**2),(h(t)=varf(t)),%logdensity(h,u)
 (Q1: dlogdm-meanf  is calculated once (per individual/per evaluation) as said in RM for FRML. This means for each t, dlogdm-meanf is calculated and assigned to u(SERIES), then used to calculate each uu(t). It seems that if I remove (t), then it still functions well  "frml logl = (u=dlogdm-meanf),(uu=u**2),(h=varf),%logdensity(h,u) " So the question is that WHERE (t) is compulsory?)
(Q2: Is this the way to calculate sigma_square recursively, how the likelihood function is summed up? In RM, %logdensity is said to use h as Symmetric and u as Vector, but they seem to be series here. )
maximize(parmset=meanparms+garchparms) logl 3 *   ( It seems that MAXIMIZE function has an option called RECURSIVE, but I did not find it in RM7.0.How is that used? Like the code(From TSAY's textbook) I listed as following )
all 0 792:1
open data sp500.txt
data(org=obs) / rt
set h  = 0.0
nonlin mu a0 a1 b1
frml at = rt(t)-mu
frml gvar = a0+a1*at(t-1)**2+b1*h(t-1)
frml garchln = -0.5*log(h(t)=gvar(t))-0.5*at(t)**2/h(t)
smpl 2 792
compute a0 = 0.01,a1 = 0.1,b1 = 0.5,mu = 0.1
maximize(method=bhhh,recursive,iterations=150) garchln
Re: Using Maximize with GARCH model
ivory4 wrote:UG---GARCHUV
Thanks in advance.
linreg dlogdm
(Without followed by a MAXIMIZE NLLS or DLM, this is only for assigning parameter values (BETA(1) BETA(2) here) to MEANPARMS defined in PARMSET?)
I'm not sure what you're asking. It defines a PARMSET named MEANPARMS which has the vector BETA (whatever is in it) as its members. At this point, BETA is the 2-vector of coefficients in the MEANF formula, which are initialized to the least squares estimates.
ivory4 wrote:
set uu = %seesq
set h  = %seesq
set u  = 0.0
(Q2: Is this the way to calculate sigma_square recursively, then how the likelihood function is summed up? In RM, %logdensity is said to use h as Symmetric and u as Vector, but they seem to be series here. )
Q1: Whereever you have a series (of any type) or FRML (of any type) within another formula, the (t) to reference the current entry is optional. Here all the (t)'s could be removed without a problem. It sometimes helps to clarify that something is a series or formula, rather than being a "temporary" real.
Q2: %logdensity can take either a N x N symmetric for the covariance matrix and N vector for the "x", or scalars for both as 1 x 1 special cases.
RECURSIVE used to be an option which changed the order of calculation inside MAXIMIZE when it did numerical derivatives. The only minor advantage (in scratch memory) for the "non-recursive" calculation was removed many years ago so what the RECURSIVE option requested is what is always done now. It's still accepted, but has no effect.
ivory4
[quote="TomDoan]
Q2: %logdensity can take either a N x N symmetric for the covariance matrix and N vector for the "x", or scalars for both as 1 x 1 special cases.[/quote]
Q1&Q2: I see. I mixed MAXIMIZE with other cases where joint likelihood is the argument.
I think it works the same way but the results are still slightly different from using GARCH command directly
linreg rt  / at
# constant rt{1 to 3}
compute beta=%beta
set h = %seesq
nonlin(parmset=garchparms) beta c a b
frml varf = c+a*at{1}**2+b*h{1}
frml garchln = -0.5*log(h(t)=varf(t))-0.5*at(t)**2/h(t)
maximize(parmset=garchparms) garchln 5 792
