Gray Regime Switching GARCH model
joannytan
Unread post by joannytan »
I would like to implement the Gray's (1996) generalized regime switching GARCH model. I have tested with a sample series by changing the original codes to suit my data, it runs ok. However, I would like to run thousand of series using the same procedure to get the variance residuals (H) for each series. I have attached the selected sample data and sample modified programs below.
I have no idea on where to put the dofor and end dofor and how to stack the output of H in a matrix. Any ideas on this?
p/s: as in the code you will notice that the dependent variables is "satn", which is my first series.
Gray.PRG
(2.37 KiB) Downloaded 1276 times
data.txt
(13.73 KiB) Downloaded 1273 times
Re: Gray Regime Switching GARCH model
Is the only thing changing from one to the next the dependent variable, or are you also changing the regressors? The former is relatively easy, since you just use a generic name like "Y" for the dependent variable in the RegimeGARCHF function, and you copy the next dependent variable into Y with a SET instruction at the top of the loop.
I'm not sure how you want to "stack" the residuals. Did you want to analyze them as cross sections?
joannytan
Yes. It is just the changing of the dependent variable. As for the residuals, each dependent variable will have one series of residuals so (eg: 6 dependent variables = 6 columns of residuals).
As this is the first time to use RATS, I have no idea on how RATS could identify the first valid and the last valid observations, I tried the code below. It doesnt seems right, but it give me the result. However, should I put the code below inside the RegimeFunction? The reason being for this is each dependent variables will have different ending and starting time period (with NA if it is not valid).
* this is to start the data with non missing values.
	do t = 1, 2008:12
	if %valid(satn(t))==0
	com first=t+1
	end do t
	* this is to end the data with valid values.
	do t = 1, 2008:12
	if %valid(satn(t))==1
	com last=t
	end do t
Try
inquire(series=satn) first last
joannytan
Thanks Tom. I got the program working now. However, I do not know how to use the set instructions, thus I follow Enders' manual and do "scratch" (to create the H series) and use "dofor y= satn tmil apma auhs..." (for looping).
Anyway thanks again.
joannytan
Hi, I did some mistake in the program, after the correction, it doesn't work anymore.
OPEN DATA "data.txt"
CALENDAR(M) 1990
DATA(FORMAT=PRN,ORG=COLUMNS) 1990:01 2008:12 SATN TMIL APMA AUHS AUVE BSAI RP SMB HML
source markov.src
compute nstates=2
dec rect p(nstates-1,nstates)
dec vect pstar(nstates)
dec series[vect] pt_t pt_t1 psmooth
gset pt_t    1 2008:12 = %zeros(nstates,1)
gset pt_t1   1 2008:12 = %zeros(nstates,1)
gset psmooth 1 2008:12 = %zeros(nstates,1)
	dofor y = SATN TMIL APMA AUHS AUVE BSAI
	linreg(noprint,robust) y
	# constant rp smb hml
	compute olsvar=%seesq
	compute olsbeta=%beta
	garch(noprint, p=1,q=1,reg,resids=u,hseries=h) / y
	# constant rp hml smb
	compute onestate=%beta
	set usqr = u**2/h
	nonlin a01 a02 a11 a12 a21 a22 a31 a32 b01 b11 b21 b02 b12 b22 p
	compute a01=%beta(1),a11=%beta(2),a21=%beta(3), a31=%beta(4), b01=olsvar,b11=0.0,b21=0.0
	compute a02=%beta(1),a12=%beta(2),a22=%beta(3), a32=%beta(4), b02=%beta(5),b12=%beta(6),b22=%beta(7)
	compute p=||.95,.05||
	set uu = olsvar
	set h  = olsvar
	function RegimeGARCHF t
	type vector RegimeGARCHF
	type integer t
	local real hh1 hh2 mu1 mu2 mu
	* Compute state dependent variances
	compute hh1=b01+b11*uu(t-1)+b21*h(t-1)
	compute hh2=b02+b12*uu(t-1)+b22*h(t-1)
	* Compute state dependent means
	compute mu1=a01+a11*rp(t)+a21*smb(t)+a31*hml(t)
	compute mu2=a02+a12*rp(t)+a22*smb(t)+a32*hml(t)
	* Compute the return vector (densities in the two states)
	compute RegimeGARCHF=||%density((y(t)-mu1)/sqrt(hh1))/sqrt(hh1),$
                       %density((y(t)-mu2)/sqrt(hh2))/sqrt(hh2)||
	* Compute the values of uu (squared residual) and h (variance) to be used for
	* the period following
	compute mu=mu1*pstar(1)+mu2*pstar(2)
	compute uu(t)=(y(t)-mu)**2
	compute h(t)=pstar(1)*(mu1**2+hh1)+pstar(2)*(mu2**2+hh2)-mu**2
	inquire(series=y) first last
	frml logl = f=RegimeGARCHF(t),$
     pt_t1=%mcstate(p,pstar),pt_t=pstar=%msupdate(f,pt_t1,fpt),log(fpt)
	maximize(start=(pstar=%mcergodic(p)),method=bfgs,iters=100,pmethod=simplex,piters=50) logl first last
 	end dofor
I got the error of "PROCEDURE/FUNCTION Must be Initial Statement in a Compiled Section". I also have tried to put the RegimeGarch Function before I start the loop, however, the error is "SX17. Missing Operator or Adjacent Operands >>>>RCHF=||%density((y(<<<<".
Your help is much appreciated.
Pull the function definition outside the loop.
CALENDAR(M) 1990
source markov.src
compute nstates=2
dec series y
   type integer t
   compute uu(t)=(tmil(t)-mu)**2
   set usqr = u**2/h
   set uu = olsvar
   set h  = olsvar
   end dofor
joannytan
Yes, I did tried this before with putting the function outside the loop but it seems like the function is not standalone, as this error appears "## SX11. Identifier B01 is Not Recognizable. Incorrect Option Field or Parameter Order? >>>> compute hh1=b01+b<<<<".
You'll have to do some additional re-arranging. The nonlin instruction needs to be pulled up above the function definition since it defines the B01 and others. You may need to add a few DECLARE instructions just to make sure that anything needed in the function are at least known variables, even if they aren't actually given working values until inside the loop.
joannytan
Hi Tom, yes it is working fine now.
sana
Unread post by sana »
joannytan wrote:Hi Tom, yes it is working fine now.
Hi
Please can I get the final code.
Your help will be much appreciated.
