just-identified SVAR
miguel
Unread post by miguel »
I am not familiar with running Monte Carlos in RATS.
Could anyone please tell me how I must modify the MCVARdodraws procedure so that the factor that was obtained with the shortandlong procedure is
used instead of the standard Cholesky factorization? (for a just-identified SVAR)
The standard MCVARdodraws procedure reads:
compute fxx    =%decomp(%xx)
compute fwish  =%decomp(inv(%nobs*%sigma))
compute betaols=%modelgetcoeffs(model)
compute wishdof=%nobs-%rows(fxx)
infobox(action=define,progress,lower=1,upper=draws) "Monte Carlo Integration"
do draw = 1,draws
   if %clock(draw,2)==1 {
      compute sigmad  =%ranwisharti(fwish,wishdof)
      compute fsigmad =%decomp(sigmad)
      compute betau   =%ranmvkron(fsigmad,fxx)
   else
   compute %modelsetcoeffs(model,betadraw)
   impulse(noprint,model=model,results=impulses,steps=steps,$
     factor=fsigmad)
   dim %%responses(draw)(%rows(impulses)*%cols(impulses),steps)
   infobox(current=draw)
many thanks in advance!
Re: just-identified SVAR
It's very similar to the BQDODRAWS procedure. As with BQDODRAWS, you need the extra step of recalculating the lag sum matrix for each new set of coefficients. In what you have, you would replace the IMPULSE instruction with
compute phiinv=inv(%modellagsums(model))
@ShortAndLong(lr=lr,sr=sr,masum=phiinv) sigmad sfactor
factor=sfactor)
where the LR and SR matrices should already be defined before you start the Monte Carlo loop. There's a full example at:
http://www.estima.com/forum/viewtopic.php?f=8&t=1118
miguel
Thanks. I did this replacement exactly and the sr and lr matrices are pre-specified, but now I get
The Error Occurred At Location 1691 of SHORTANDLONG
Line 123 of SHORTANDLONG
Line 63 of MCVARDODRAWS
Line 123 of shortandlong reads
compute %psubmat(r,fill,(j-1)*n+1,%xrow(masums,i))
Any idea what is going wrong?
What are your short and long run matrices? You're probably using a model which isn't identified properly.
