CKLS Model for Interest Rates
Note: a replication with the original data set and parameterization are now available at:
http://www.estima.com/forum/viewtopic.php?f=8&t=997
The following uses various GMM procedures to estimate interest rate model with discrete time data.
* Estimation of CKLS model for interest rates.
* Reference: Chan, Karolyi, Longstaff and Sanders(1992), "Comparison of
* Models of the Short-Term Interest Rate" Journal of Finance, vol 47, no
* 3, 1209-1227.
* (This is not the original data set, or data range).
open data tbills.xls
calendar(m) 1946:1
data(format=xls,org=columns) 1946:01 2011:01 tb3ms
set y1 = tb3ms*.01
set dy = y1-y1{1}
nonlin alpha beta gamma sigmasq
frml eps = y1{-1}-(1+beta)*y1-alpha
frml variance = eps(t)^2-sigmasq*y1^(2*gamma)
* Just identified model
instruments constant y1
nlsystem(instruments) / eps variance
* Overidentified model
* With nozudep
instruments constant y1{0 1}
* Same thing, but correcting the covariance matrix and J-statistic
nlsystem(instruments,robusterrors) / eps variance
* With ZUDEP
nlsystem(instruments,zudep) / eps variance
Data file:
tbills.xls
(28.59 KiB) Downloaded 884 times
Tony
Re: CKLS Model for Interest Rates
Unread post by Tony »
I have been reading on how to forecast based on NLLS models or GMM from the user guide. It was told that we need to group before do any forecasting. But I still cannot understand it. Can you kindly show to us step by step how to do it using the CKLS model as example.
The CKLS model is basically just a one lag autoregression; it's written in a different form in order to estimate it along with the variance equation by GMM. In order to forecast, you just need to create an equation which has the same content.
Re-dating this to make current (rather than future) y1 as the dependent variable gives:
equation(coeffs=||1+beta,alpha||) y1eq y1
# y1{1} constant
You can then forecast that by itself with something as simple as UFORECAST.
