Generating observations with an AR(1) Model
tomsmith
Unread post by tomsmith »
That works fine, thanks
Re: Generating observations with an AR(1) Model
The Johnston and DiNardo example johnp059.rpf and the Hamilton example hamp055.rpf are almost spot-on for what you want to do. The Johnston example uses the same "shocks" for each process, while the Hamilton one draws them independently.
