Scatter with data labels
slackscholar
Unread post by slackscholar »
Would it be possible to make an X-Y scatter plot that comes with a label on each (x,y) point?
thanks!
Site Admin
Re: Scatter with data labels
Unread post by moderator »
Yes, you can use GRTEXT to do that. You need to wrap the whole thing in an SPGRAPH, do the SCATTER and then do a GRTEXT command for each point you want to label. You'll probably want to use a loop over the entries to do that. Use the Y option and either the ENTRY or X option to specify the positioning of the labels.
For something similar, see the second example under GRTEXT in the Reference Manual.
Tom Maycock
Estima
slackscholar
Thank you so much for the prompt reply!
It works!
