Identifier LAGS is Not Recognizable
atjanke
Post by atjanke »
Hi Everyone,
I am new to this board, RATS and time series generally. I am trying to write a very simple (practice) procedure which gives me the statistics of a series restricted depending on previous values. So, I want my procedure to tell me the statistics of a series if I restrict the series to the observations which are preceded by two periods of values greater than zero (for example).
I am getting this error which I try to source the code file:
## SX11. Identifier LAGS is Not Recognizable. Incorrect Option Field or Parameter Order?
>>>> if 2==lags<<<<
I've spent some time pouring over the User Guide and Reference Manual, but can't seem to find the problem. I want to be able to use 'series' and 'lags' in the code. Hope you can help. Thanks.
procedure unit series
type series series
local series
OPTION INTEGER lags
OPTION REAL shock 0
set first = %if(series{1}>shock,1,0)
set second = %if(series{2}>shock,1,0)
set third = %if(series{3}>shock,1,0)
set fourth = %if(series{4}>shock,1,0)
set fifth = %if(series{5}>shock,1,0)
set sixth = %if(series{6}>shock,1,0)
set seventh = %if(series{7}>shock,1,0)
set eighth = %if(series{8}>shock,1,0)
set ninth = %if(series{9}>shock,1,0)
set tenth = %if(series{10}>shock,1,0)
set eleventh = %if(series{11}>shock,1,0)
set twelfth = %if(series{12}>shock,1,0)
	if 1==lags
		set great = %if(first = 1,1,0)
		dis 'If we restrict the series to values preceded by chosen shocks, then we obtain the following data.'
		stat(smpl=great) series
	end if
	if 2==lags
		set great = %if(first + second = 2,1,0)
	end if
	if 3==lags
		set great = %if(first+second+third = 3,1,0)
	end if
	if 4==lags
		set great = %if(first+second+third+fourth = 4,1,0)
	end if
	if 5==lags
		set great = %if(first+second+third+fourth+fifth = 5,1,0)
	end if
	if 6=lags
		set great = %if(first+second+third+fourth+fifth+sixth = 6,1,0)
	end if
	if 7==lags
		set great = %if(first+second+third+fourth+fifth+sixth+seventh = 7,1,0)
		stat(smpl=great) (series)
	end if
	if 8==lags
		set great = %if(first+second+third+fourth+fifth+sixth+seventh+eighth = 8,1,0)
	end if
	if 9==lags
		set great = %if(first+second+third+fourth+fifth+sixth+seventh+eighth+ninth = 9,1,0)
	end if
	if 10==lags
		set great = %if(first+second+third+fourth+fifth+sixth+seventh+eighth+ninth+tenth = 10,1,0)
	end if
	if 11==lags
		set great = %if(first+second+third+fourth+fifth+sixth+seventh+eighth+ninth+tenth+eleventh = 11,1,0)
	end if
	if 12==lags
		set great = %if(first+second+third+fourth+fifth+sixth+seventh+eighth+ninth+tenth+eleventh+twelfth = 12,1,0)
	end if
end unit
Re: Identifier LAGS is Not Recognizable
Post by TomDoan »
RATS is not an "IF---END IF" language; instead it's an IF {...} language. So instead of:
	if 1==lags
	end if
You want
	if 1==lags {
(and similarly for all the other such constructions in your procedure). The END IF's become END's for the procedure itself, hence the option LAGS is no longer an active variable.
Also, in that SET GREAT instruction, you want to use FIRST==1, not FIRST=1. The latter is legal (assigns the value 1 to FIRST), but obviously isn't what you want.
atjanke
Post by atjanke »
I have fixed those mistakes. But I am still getting the same error message:
>>>> if 2==lags {<<<<
Thanks a bunch for the help.
type series series
local series
OPTION INTEGER lags
OPTION REAL shock 0
	if 1==lags {
		set great = %if(first == 1,1,0)
	end if
	if 2==lags {
		set great = %if(first + second == 2,1,0)
	end if
	if 3==lags {
		set great = %if(first+second+third == 3,1,0)
	end if
	if 4==lags {
		set great = %if(first+second+third+fourth == 4,1,0)
	end if
	if 5==lags {
		set great = %if(first+second+third+fourth+fifth == 5,1,0)
	end if
	if 6=lags {
		set great = %if(first+second+third+fourth+fifth+sixth == 6,1,0)
	end if
	if 7==lags {
		set great = %if(first+second+third+fourth+fifth+sixth+seventh == 7,1,0)
	end if
	if 8==lags {
		set great = %if(first+second+third+fourth+fifth+sixth+seventh+eighth == 8,1,0)
	end if
	if 9==lags {
		set great = %if(first+second+third+fourth+fifth+sixth+seventh+eighth+ninth == 9,1,0)
	end if
	if 10==lags {
		set great = %if(first+second+third+fourth+fifth+sixth+seventh+eighth+ninth+tenth == 10,1,0)
	end if
	if 11==lags {
		set great = %if(first+second+third+fourth+fifth+sixth+seventh+eighth+ninth+tenth+eleventh == 11,1,0)
	end if
	if 12==lags {
		set great = %if(first+second+third+fourth+fifth+sixth+seventh+eighth+ninth+tenth+eleventh+twelfth == 12,1,0)
	end if
end unit
Post by TomDoan »
You put in the {...}, but didn't delete the END IF's. You have to do both.
