OLSHODRICK—Least squares with Hodrick standard errors
@OLSHODRICK computes a least squares regression with the covariance matrix proposed by Hodrick(1992) "Dividend Yields and Expected Stock Returns: Alternative Procedures for Inference and Measurement", Review of Financial Studies, vol 5, no 3, 357-386.
Note that the calculation is specific to multiple step predictability regressions. It uses the residuals from a one-step regression to compute the covariance matrix for a k-step regression.
OLSHodrick.src
Detailed description
OLSHodrick.src
OLSHodrick gives 0 standard error?
Hi all. I'm doing data analysis for my thesis. For some reason, when running regression involving one regressor, del_l_n, RATS gives stadard error of 0 to all regressors, which definitely doesn't look right. I've attached my source and an example is:
@OLSHodrick(steps=1,onestep=z41) z41
# constant del_bdi_lag del_crb del_l_n
Linear Regression - Estimation by Least Squares with Hodrick standard errors
Dependent Variable Z41
Monthly Data From 1986:04 To 2017:04
Usable Observations 369
Degrees of Freedom 365
Skipped/Missing (from 373) 4
Mean of Dependent Variable 0.0021704629
Std Error of Dependent Variable 0.0134891456
Standard Error of Estimate 0.0131667459
Sum of Squared Residuals 0.0632775673
Durbin-Watson Statistic 1.8905
1. Constant 0.0020714824 0.0000000000 0.00000 0.00000000
2. DEL_BDI_LAG 0.0000036880 0.0000000000 0.00000 0.00000000
3. DEL_CRB 0.0735049493 0.0000000000 0.00000 0.00000000
4. DEL_L_N 0.0071249449 0.0000000000 0.00000 0.00000000
Can anyone suggest why this is the case? I've also tried the same spec using Newey-West standard errors and they definitely shouldn't be 0.
Thank you,
Keith
Thank you,
Keith
- agg new.xlsx
- (91.67 KiB) Downloaded 783 times
Re: OLSHODRICK - Least squares with Hodrick standard errors
Hodrick standard errors don't apply to one-step forecasts.
Hi. Do you you mean this function doesn't support 1-step ahaead forecasts? Because Hodrick (1992) should be applicable, see, for example, Predictability of currency carry trade and asset pricing implications, Journal of Financial Economics, Bakshi and panayotov (2013).TomDoan wrote:Hodrick standard errors don't apply to one-step forecasts.
Also, del_l_n is the only variable that gives this error; the other regressors (del_crb, del_ted, etc) give correct errors.
Re: OLSHODRICK—Least squares with Hodrick standard errors
Because del_l_n is missing 4 data points in the middle. The Hodrick standard errors formula doesn't allow for missing values in the middle. Note that "Hodrick" standard errors with steps=1 are just Eicker-White errors and LINREG(ROBUSTERRORS) is perfectly happy with missing values. The whole point of Hodrick's paper is to deal with multi-step predictability where there's an issue with serially correlated residuals.
Many thanks Tom.TomDoan wrote:Because del_l_n is missing 4 data points in the middle. The Hodrick standard errors formula doesn't allow for missing values in the middle. Note that "Hodrick" standard errors with steps=1 are just Eicker-White errors and LINREG(ROBUSTERRORS) is perfectly happy with missing values. The whole point of Hodrick's paper is to deal with multi-step predictability where there's an issue with serially correlated residuals.
