Balcilar, et al EE(2015)
Re: Balcilar, et al EE(2015)
I'd be hard-pressed to think of a practical situation in which that test has any value. It isn't a test of whether or not a MS model is proper. If you look at page 151, you will see that simple MS AR models are considered to be examples of DGP's which are supposed to be rejected by the test.
n_khraief
Unread post by n_khraief »
Thank you Tom.
Olease I tried to run Balcilar code in my data basis (file attached) but the itérations stopped and I've got this error message:
Likelihood Based Analysis of Cointegration
Variables:  LOIL LSP
Estimated from 1950:03 to 2104:04
Data Points 1850 Lags 2 with Constant
  Rank     EigVal  Lambda-max Trace  Trace-95%     LogL
        0                                      -130930.6508
        1   0.0039     7.2123 7.6884   15.4100 -130927.0447
        2   0.0003     0.4761 0.4761    3.8400 -130926.8066
LOIL      LSP
-0.000000 0.000000
VAR/System - Estimation by Cointegrated Least Squares
Monthly Data From 1950:03 To 2104:04
Usable Observations                      1850
Dependent Variable LOIL
Mean of Dependent Variable       2.47543e+013
Std Error of Dependent Variable  5.39263e+014
Standard Error of Estimate       5.21604e+014
Sum of Squared Residuals         5.02243e+032
Durbin-Watson Statistic                1.9943
1.  D_LOIL{1}                          0.2850       0.0253     11.26168  0.00000000
2.  D_LSP{1}                          -0.1189       0.0195     -6.08521  0.00000000
3.  Constant                      8.4214e+012  1.3910e+013      0.60543  0.54496540
4.  EC1{1}                       -4.7991e-003  2.2980e-003     -2.08839  0.03689944
Dependent Variable LSP
Mean of Dependent Variable       4.05337e+013
Std Error of Dependent Variable  6.98487e+014
Standard Error of Estimate       6.98380e+014
Sum of Squared Residuals         9.00358e+032
Durbin-Watson Statistic                1.9971
1.  D_LOIL{1}                         -0.0451       0.0339     -1.33061  0.18348143
2.  D_LSP{1}                           0.0457       0.0262      1.74940  0.08038871
3.  Constant                      4.4079e+013  1.8624e+013      2.36681  0.01804458
4.  EC1{1}                        1.4555e-003  3.0768e-003      0.47306  0.63622464
Iteration 1 Log likelihood -129090.32950
Iteration 2 Log likelihood -128184.50282
Iteration 3 Log likelihood -127477.25329
Iteration 4 Log likelihood -126552.42409
Iteration 5 Log likelihood -125355.52425
Iteration 6 Log likelihood -123819.46950
Iteration 7 Log likelihood -121393.73663
Iteration 8 Log likelihood -118943.06771
Iteration 9 Log likelihood -115382.57821
Iteration 10 Log likelihood  -94576.15609
Iteration 11 Log likelihood  -94397.99439
Iteration 12 Log likelihood  -94257.82103
Iteration 13 Log likelihood  -94181.03354
Iteration 14 Log likelihood  -94137.35209
Iteration 15 Log likelihood  -94126.77374
Iteration 16 Log likelihood  -94126.77365
Iteration 17 Log likelihood  -94126.77363
Iteration 18 Log likelihood  -94126.77362
Iteration 19 Log likelihood  -94126.77363
Iteration 20 Log likelihood  -94126.77362
Iteration 21 Log likelihood  -94126.77362
Iteration 22 Log likelihood  -94126.77363
Iteration 23 Log likelihood  -94126.77363
Iteration 24 Log likelihood  -94126.77363
Iteration 25 Log likelihood  -94126.77363
Iteration 26 Log likelihood  -94126.77362
Iteration 27 Log likelihood  -94126.77363
Iteration 28 Log likelihood  -94126.77362
Iteration 29 Log likelihood  -94126.77362
Iteration 30 Log likelihood  -94126.77362
Iteration 31 Log likelihood  -94126.77362
Iteration 32 Log likelihood  -94126.77362
Iteration 33 Log likelihood  -94126.77362
Iteration 34 Log likelihood  -94126.77362
Iteration 35 Log likelihood  -94126.77363
Iteration 36 Log likelihood  -94126.77363
Iteration 37 Log likelihood  -94126.77363
Iteration 38 Log likelihood  -94126.77363
Iteration 39 Log likelihood  -94126.77363
Iteration 40 Log likelihood  -94126.77362
Iteration 41 Log likelihood  -94126.77362
Iteration 42 Log likelihood  -94126.77363
Iteration 43 Log likelihood  -94126.77362
Iteration 44 Log likelihood  -94126.77362
Iteration 45 Log likelihood  -94126.77363
Iteration 46 Log likelihood  -94126.77362
Iteration 47 Log likelihood  -94126.77363
Iteration 48 Log likelihood  -94126.77363
Iteration 49 Log likelihood  -94126.77362
Iteration 50 Log likelihood  -94126.77362
Iteration 51 Log likelihood  -94126.77363
Iteration 52 Log likelihood  -94126.77362
Iteration 53 Log likelihood  -94126.77363
Iteration 54 Log likelihood  -94126.77362
Iteration 55 Log likelihood  -94126.77363
Iteration 56 Log likelihood  -94126.77363
Iteration 57 Log likelihood  -94126.77363
Iteration 58 Log likelihood  -94126.77363
Iteration 59 Log likelihood  -94126.77363
Iteration 60 Log likelihood  -94126.77362
Iteration 61 Log likelihood  -94126.77362
Iteration 62 Log likelihood  -94126.77362
Iteration 63 Log likelihood  -94126.77362
Iteration 64 Log likelihood  -94126.77362
Iteration 65 Log likelihood  -94126.77362
Iteration 66 Log likelihood  -94126.77363
Iteration 67 Log likelihood  -94126.77363
Iteration 68 Log likelihood  -94126.77363
Iteration 69 Log likelihood  -94126.77363
Iteration 70 Log likelihood  -94126.77363
Iteration 71 Log likelihood  -94126.77363
Iteration 72 Log likelihood  -94126.77363
Iteration 73 Log likelihood  -94126.77363
Iteration 74 Log likelihood  -94126.77362
Iteration 75 Log likelihood  -94126.77363
Iteration 76 Log likelihood  -94126.77362
Iteration 77 Log likelihood  -94126.77363
Iteration 78 Log likelihood  -94126.77362
Iteration 79 Log likelihood  -94126.77362
Iteration 80 Log likelihood  -94126.77362
Iteration 81 Log likelihood  -94126.77362
Iteration 82 Log likelihood  -94126.77365
Iteration 83 Log likelihood  -94126.77362
Iteration 84 Log likelihood  -94126.77363
Iteration 85 Log likelihood  -94126.77363
Iteration 86 Log likelihood  -94126.77363
Iteration 87 Log likelihood  -94126.77363
Iteration 88 Log likelihood  -94126.77362
Iteration 89 Log likelihood  -94126.77362
Iteration 90 Log likelihood  -94126.77363
Iteration 91 Log likelihood  -94126.77362
Iteration 92 Log likelihood  -94126.77362
Iteration 93 Log likelihood  -94126.77363
Iteration 94 Log likelihood  -94126.77362
Iteration 95 Log likelihood  -94126.77363
Iteration 96 Log likelihood  -94126.77363
Iteration 97 Log likelihood  -94126.77362
Iteration 98 Log likelihood  -94126.77363
Iteration 99 Log likelihood  -94126.77363
Iteration 100 Log likelihood  -94126.77363
MAXIMIZE - Estimation by BHHH
Convergence in     6 Iterations. Final criterion was  0.0000000 <=  0.0000100
Function Value                        NA
1.  BETASYS(1)(1,1)                   -0.0544       0.0168      -3.23562  0.00121379
2.  BETASYS(1)(2,1)                 -128.1988   85560.2197      -0.00150  0.99880449
3.  BETASYS(1)(3,1)               1.3303e+013  9.4734e+013       0.14042  0.88832620
4.  BETASYS(1)(4,1)                   -0.4270  8.3870e-003     -50.91458  0.00000000
5.  BETASYS(1)(1,2)              -2.9575e+017       0.0000       0.00000  0.00000000
6.  BETASYS(1)(2,2)              -2.8757e+009  3.9049e-003 -7.36438e+011  0.00000000
7.  BETASYS(1)(3,2)                   -1.3108       4.9994      -0.26219  0.79317504
8.  BETASYS(1)(4,2)              -7.9079e+017       0.0000       0.00000  0.00000000
9.  BETASYS(2)(1,1)                    0.0503       0.0690       0.72881  0.46611488
10. BETASYS(2)(2,1)                   -0.0590       0.1024      -0.57646  0.56430094
11. BETASYS(2)(3,1)               8.9176e+013  1.0660e+014       0.83651  0.40286601
12. BETASYS(2)(4,1)                   -0.0267       0.0171      -1.56217  0.11824822
13. BETASYS(2)(1,2)                   -0.1362       0.0367      -3.71353  0.00020439
14. BETASYS(2)(2,2)                    0.2891       0.0572       5.05719  0.00000043
15. BETASYS(2)(3,2)               2.8568e+013  6.1289e+013       0.46612  0.64113064
16. BETASYS(2)(4,2)                   -0.0453       0.0100      -4.53215  0.00000584
17. SIGMAV(1)(1,1)                5.8804e+028  2.4320e+027      24.17884  0.00000000
18. SIGMAV(1)(2,1)                1.3964e+013  2.2061e+016  6.32994e-004  0.99949494
19. SIGMAV(1)(2,2)                   306.6247      10.9122      28.09924  0.00000000
20. SIGMAV(2)(1,1)                1.2423e+030  3.2721e+028      37.96582  0.00000000
21. SIGMAV(2)(2,1)                4.8867e+029  2.9492e+028      16.56952  0.00000000
22. SIGMAV(2)(2,2)                7.4825e+029  4.0840e+028      18.32152  0.00000000
23. P(1,1)                           108.3622  5.9904e-003   18089.37455  0.00000000
24. P(1,2)                            61.6142       0.0114    5418.10841  0.00000000
The Error Occurred At Location 408, Line 24 of loop/block.
us-ms1.xlsx
my data basis
(71.44 KiB) Downloaded 823 times
  1. Why is that running through 2104:4? The actual data are only through 2015:10
  2. The first almost 20 years of LSP are clearly nothing like the remainder of the sample.
  3. The last five years of LOIL look like a whole string of typos.
n_khraief
Thank you Tom, the error is seemingly resolved and I've got the following results: (But I have a doubt if there is a difference between the two regimes)
Variables:  LOIL LSP
Estimated from 1950:03 to 2015:10
Data Points 788 Lags 2 with Constant
       0                                       -6485.1302
       1   0.0442    35.6090 35.7655   15.4100 -6467.3257
       2   0.0002     0.1565  0.1565    3.8400 -6467.2474
LOIL     LSP
0.010416 0.001617
Monthly Data From 1950:03 To 2015:10
Usable Observations                       788
Mean of Dependent Variable        0.038837060
Std Error of Dependent Variable  59.574599813
Standard Error of Estimate       54.144916095
Sum of Squared Residuals         2298430.8001
Durbin-Watson Statistic                2.1673
1.  D_LOIL{1}                     -0.31269669   0.03410946     -9.16745  0.00000000
2.  D_LSP{1}                      -0.15188278   0.46483184     -0.32675  0.74394586
3.  Constant                      23.01058805   4.28419220      5.37104  0.00000010
4.  EC1{1}                        -0.12091822   0.02009003     -6.01882  0.00000000
Mean of Dependent Variable       0.4420933500
Std Error of Dependent Variable  4.1524271233
Standard Error of Estimate       3.9865167460
Sum of Squared Residuals         12459.575561
Durbin-Watson Statistic                1.9260
1.  D_LOIL{1}                     0.002050693  0.002511370      0.81656  0.41442600
2.  D_LSP{1}                      0.284761011  0.034224080      8.32049  0.00000000
3.  Constant                      0.375513340  0.315431349      1.19048  0.23421983
4.  EC1{1}                       -0.000307871  0.001479164     -0.20814  0.83517494
Iteration 1 Log likelihood   -5894.30993
Iteration 2 Log likelihood   -5574.21692
Iteration 3 Log likelihood   -5505.89913
Iteration 4 Log likelihood   -5478.86113
Iteration 5 Log likelihood   -5467.90627
Iteration 6 Log likelihood   -5461.49524
Iteration 7 Log likelihood   -5457.53022
Iteration 8 Log likelihood   -5455.24922
Iteration 9 Log likelihood   -5453.24680
Iteration 10 Log likelihood   -5451.68453
Iteration 11 Log likelihood   -5451.04173
Iteration 12 Log likelihood   -5450.72641
Iteration 13 Log likelihood   -5450.27190
Iteration 14 Log likelihood   -5449.45712
Iteration 15 Log likelihood   -5449.07281
Iteration 16 Log likelihood   -5449.04759
Iteration 17 Log likelihood   -5449.04486
Iteration 18 Log likelihood   -5449.04423
Iteration 19 Log likelihood   -5449.04406
Iteration 20 Log likelihood   -5449.04401
Iteration 21 Log likelihood   -5449.04399
Iteration 22 Log likelihood   -5449.04399
Iteration 23 Log likelihood   -5449.04399
Iteration 24 Log likelihood   -5449.04399
Iteration 25 Log likelihood   -5449.04398
Iteration 26 Log likelihood   -5449.04398
Iteration 27 Log likelihood   -5449.04398
Iteration 28 Log likelihood   -5449.04398
Iteration 29 Log likelihood   -5449.04398
Iteration 30 Log likelihood   -5449.04398
Iteration 31 Log likelihood   -5449.04398
Iteration 32 Log likelihood   -5449.04398
Iteration 33 Log likelihood   -5449.04398
Iteration 34 Log likelihood   -5449.04398
Iteration 35 Log likelihood   -5449.04398
Iteration 36 Log likelihood   -5449.04398
Iteration 37 Log likelihood   -5449.04398
Iteration 38 Log likelihood   -5449.04398
Iteration 39 Log likelihood   -5449.04398
Iteration 40 Log likelihood   -5449.04398
Iteration 41 Log likelihood   -5449.04398
Iteration 42 Log likelihood   -5449.04398
Iteration 43 Log likelihood   -5449.04398
Iteration 44 Log likelihood   -5449.04398
Iteration 45 Log likelihood   -5449.04398
Iteration 46 Log likelihood   -5449.04398
Iteration 47 Log likelihood   -5449.04398
Iteration 48 Log likelihood   -5449.04398
Iteration 49 Log likelihood   -5449.04398
Iteration 50 Log likelihood   -5449.04398
Iteration 51 Log likelihood   -5449.04398
Iteration 52 Log likelihood   -5449.04398
Iteration 53 Log likelihood   -5449.04398
Iteration 54 Log likelihood   -5449.04398
Iteration 55 Log likelihood   -5449.04398
Iteration 56 Log likelihood   -5449.04398
Iteration 57 Log likelihood   -5449.04398
Iteration 58 Log likelihood   -5449.04398
Iteration 59 Log likelihood   -5449.04398
Iteration 60 Log likelihood   -5449.04398
Iteration 61 Log likelihood   -5449.04398
Iteration 62 Log likelihood   -5449.04398
Iteration 63 Log likelihood   -5449.04398
Iteration 64 Log likelihood   -5449.04398
Iteration 65 Log likelihood   -5449.04398
Iteration 66 Log likelihood   -5449.04398
Iteration 67 Log likelihood   -5449.04398
Iteration 68 Log likelihood   -5449.04398
Iteration 69 Log likelihood   -5449.04398
Iteration 70 Log likelihood   -5449.04398
Iteration 71 Log likelihood   -5449.04398
Iteration 72 Log likelihood   -5449.04398
Iteration 73 Log likelihood   -5449.04398
Iteration 74 Log likelihood   -5449.04398
Iteration 75 Log likelihood   -5449.04398
Iteration 76 Log likelihood   -5449.04398
Iteration 77 Log likelihood   -5449.04398
Iteration 78 Log likelihood   -5449.04398
Iteration 79 Log likelihood   -5449.04398
Iteration 80 Log likelihood   -5449.04398
Iteration 81 Log likelihood   -5449.04398
Iteration 82 Log likelihood   -5449.04398
Iteration 83 Log likelihood   -5449.04398
Iteration 84 Log likelihood   -5449.04398
Iteration 85 Log likelihood   -5449.04398
Iteration 86 Log likelihood   -5449.04398
Iteration 87 Log likelihood   -5449.04398
Iteration 88 Log likelihood   -5449.04398
Iteration 89 Log likelihood   -5449.04398
Iteration 90 Log likelihood   -5449.04398
Iteration 91 Log likelihood   -5449.04398
Iteration 92 Log likelihood   -5449.04398
Iteration 93 Log likelihood   -5449.04398
Iteration 94 Log likelihood   -5449.04398
Iteration 95 Log likelihood   -5449.04398
Iteration 96 Log likelihood   -5449.04398
Iteration 97 Log likelihood   -5449.04398
Iteration 98 Log likelihood   -5449.04398
Iteration 99 Log likelihood   -5449.04398
Iteration 100 Log likelihood   -5449.04398
NO CONVERGENCE IN 10 ITERATIONS
LAST CRITERION WAS  0.0001139
Function Value                     -5449.0438
1.  BETASYS(1)(1,1)                   0.12397      0.02430      5.10099  0.00000034
2.  BETASYS(1)(2,1)                  -0.00361      0.01136     -0.31776  0.75066625
3.  BETASYS(1)(3,1)                   1.13356      0.57622      1.96724  0.04915503
4.  BETASYS(1)(4,1)                  -0.00547      0.00219     -2.50458  0.01225959
5.  BETASYS(1)(1,2)                   0.05122      0.10035      0.51042  0.60975988
6.  BETASYS(1)(2,2)                  -0.22809      0.01775    -12.84660  0.00000000
7.  BETASYS(1)(3,2)                   4.63396      0.92300      5.02053  0.00000052
8.  BETASYS(1)(4,2)                  -0.01901      0.00447     -4.24739  0.00002163
9.  BETASYS(2)(1,1)                   0.50979      0.08494      6.00143  0.00000000
10. BETASYS(2)(2,1)                  -0.00825      0.00412     -2.00168  0.04531879
11. BETASYS(2)(3,1)                   0.12182      0.64979      0.18748  0.85128120
12. BETASYS(2)(4,1)                   0.02009      0.00362      5.54443  0.00000003
13. BETASYS(2)(1,2)                   3.36521      3.08869      1.08953  0.27592179
14. BETASYS(2)(2,2)                  -0.14095      0.11715     -1.20321  0.22889329
15. BETASYS(2)(3,2)                  31.67067     17.99914      1.75957  0.07848151
16. BETASYS(2)(4,2)                  -0.47302      0.12466     -3.79442  0.00014799
17. SIGMAV(1)(1,1)                   10.79241      0.37024     29.15010  0.00000000
18. SIGMAV(1)(2,1)                   -2.19790      1.15488     -1.90314  0.05702216
19. SIGMAV(1)(2,2)                   73.97469      3.70395     19.97181  0.00000000
20. SIGMAV(2)(1,1)                   24.06180      2.79526      8.60807  0.00000000
21. SIGMAV(2)(2,1)                  166.79886     74.35291      2.24334  0.02487491
22. SIGMAV(2)(2,2)                14228.65880   1761.82446      8.07609  0.00000000
23. P(1,1)                            0.94492      0.01084     87.13180  0.00000000
24. P(1,2)                            0.25819      0.04031      6.40439  0.00000000
BETASYS(1)(1,1)     0.13981382    0.03950559
BETASYS(1)(2,1)     0.00567325    0.00359030
BETASYS(1)(3,1)     1.24845289    0.44402585
BETASYS(1)(4,1)    -0.00581339    0.00198707
BETASYS(1)(1,2)     0.08019588    0.09167914
BETASYS(1)(2,2)    -0.01736670    0.00935412
BETASYS(1)(3,2)     4.46483839    1.32789380
BETASYS(1)(4,2)    -0.01851016    0.00575689
BETASYS(2)(1,1)     0.50123744    0.09975046
BETASYS(2)(2,1)    -0.01387026    0.00486193
BETASYS(2)(3,1)    -0.38828681    0.55506477
BETASYS(2)(4,1)     0.02157813    0.00420078
BETASYS(2)(1,2)     2.65543291    2.10351403
BETASYS(2)(2,2)    -0.33035931    0.10757068
BETASYS(2)(3,2)    16.21551292   12.26880215
BETASYS(2)(4,2)    -0.38242882    0.08912892
SIGMAV(1)(1,1)     11.45711570    0.78742488
SIGMAV(1)(2,1)     -1.45143364    1.26675558
SIGMAV(1)(2,2)     78.85892060    6.19259723
SIGMAV(2)(1,1)     22.92361397    2.94212684
SIGMAV(2)(2,1)    113.69881518   43.59348053
SIGMAV(2)(2,2)  11602.77174878 1386.25193319
P(1,1)              0.94479115    0.00000000
P(2,1)              0.05520885    0.00000000
P(1,2)              0.25767045    0.00000000
P(2,2)              0.74232955    0.00000000
Response of Stock Price to Stock Price Shock in Regime 1
 ENTRY       IRF(1,1)       LOWER(1,1)      UPPER(1,1)
 1950:01   1.000000000000  1.000000000000  1.000000000000
 1950:02   1.133393018125  1.067378271602  1.197993008962
 1950:03   1.147456581127  1.066817340527  1.233121290550
 1950:04   1.143197443124  1.059108351272  1.233755609434
 1950:05   1.136031860909  1.052008833567  1.228886682659
 1950:06   1.128437002169  1.044364409509  1.220441836435
 1950:07   1.120832085646  1.036951155510  1.214047692180
 1950:08   1.113290691102  1.030276928191  1.207839397258
 1950:09   1.105825672986  1.022556371781  1.201812398367
 1950:10   1.098438780932  1.014268481997  1.194798928779
 1950:11   1.091129664863  1.006170575564  1.188142139422
 1950:12   1.083897570692  0.997539636890  1.182112493682
 1951:01   1.076741670475  0.990124077425  1.175238650614
 1951:02   1.069661128614  0.982611805613  1.168202503950
 1951:03   1.062655115439  0.973336020261  1.161658600091
 1951:04   1.055722809995  0.965402188663  1.155861786216
 1951:05   1.048863400561  0.957059694669  1.150586260292
 1951:06   1.042076084676  0.948799267531  1.146533060506
 1951:07   1.035360069060  0.940997307871  1.142067136372
 1951:08   1.028714569511  0.933194130018  1.136983605490
 1951:09   1.022138810803  0.924610233761  1.131822573077
 1951:10   1.015632026576  0.915950663188  1.126556655604
Response of Stock Price to Stock Price Shock in Regime 2
 ENTRY       IRF(1,2)       LOWER(1,2)      UPPER(1,2)
 1950:01   1.00000000000   1.000000000000  1.000000000000
 1950:02   1.47028521660   1.298046966423  1.648730539986
 1950:03   1.76200865254   1.457951163080  2.115521445108
 1950:04   1.96941382036   1.572869481574  2.483222444536
 1950:05   2.14686869740   1.669535098943  2.803980883939
 1950:06   2.30957192470   1.758394181810  3.083793696544
 1950:07   2.46812540406   1.844881114945  3.362570176116
 1950:08   2.62575694045   1.928750484303  3.618853040287
 1950:09   2.78500814652   2.018176668246  3.908916031763
 1950:10   2.94676028787   2.102131882044  4.218868518973
 1950:11   3.11179260436   2.188374603445  4.531290051428
 1950:12   3.28045658784   2.268494861553  4.839210150549
 1951:01   3.45309659156   2.351013159708  5.149168852670
 1951:02   3.62993722949   2.436750285993  5.521823626625
 1951:03   3.81121119972   2.515735301331  5.878558472923
 1951:04   3.99711848125   2.602259275060  6.238520922310
 1951:05   4.18786935765   2.685263487158  6.620940530260
 1951:06   4.38366906647   2.762242111298  6.986792605367
 1951:07   4.58473375894   2.847826756099  7.365746804110
 1951:08   4.79128469725   2.922428577873  7.849732473258
 1951:09   5.00355487476   3.007130882928  8.319576802582
 1951:10   5.22178702437   3.077902584468  8.829132857142
Response of Stock Price to Oil Price Shock in Regime 1
 ENTRY       IRF(1,3)       LOWER(1,3)      UPPER(1,3)
 1950:01   0.000000000000  0.000000000000  0.000000000000
 1950:02   0.004770913515 -0.001121817357  0.010929812855
 1950:03   0.004410270694 -0.002265012543  0.011541509105
 1950:04   0.003451428357 -0.003426781172  0.010765710867
 1950:05   0.002405494952 -0.004700171586  0.009860961041
 1950:06   0.001354792389 -0.005957696024  0.009026900321
 1950:07   0.000312454362 -0.007265775109  0.008166383358
 1950:08  -0.000719377884 -0.008652344076  0.007437039049
 1950:09  -0.001740423199 -0.010054813844  0.006769397779
 1950:10  -0.002750727195 -0.011299865184  0.006091623941
 1950:11  -0.003750394273 -0.012456342944  0.005389310060
 1950:12  -0.004739538898 -0.013759467525  0.004780507499
 1951:01  -0.005718276430 -0.015088850659  0.004262540158
 1951:02  -0.006686721354 -0.016418317458  0.003727483228
 1951:03  -0.007644986933 -0.017831918294  0.003219164743
 1951:04  -0.008593185154 -0.019166326730  0.002640261694
 1951:05  -0.009531426729 -0.020342246961  0.002059751033
 1951:06  -0.010459821101 -0.021667330255  0.001505821642
 1951:07  -0.011378476463 -0.022882244767  0.000912900627
 1951:08  -0.012287499772 -0.024099366451  0.000473835676
 1951:09  -0.013186996763 -0.025240376719 -0.000119713825
 1951:10  -0.014077071962 -0.026444060471 -0.000635136981
Response of Stock Price to Oil Price Shock in Regime 2
 ENTRY       IRF(1,4)       LOWER(1,4)      UPPER(1,4)
 1950:02  -0.010520953217 -0.018035294331 -0.003304375243
 1950:03  -0.008384269604 -0.016100953464 -0.001061441411
 1950:04  -0.006472642505 -0.015004737475  0.001982322239
 1950:05  -0.002664382607 -0.011417179739  0.006066915575
 1950:06   0.001240799257 -0.007989745133  0.010248034509
 1950:07   0.005586150377 -0.003824101986  0.014946137876
 1950:08   0.010032093262 -0.000121706351  0.020031639784
 1950:09   0.014653316080  0.003876111536  0.025802164273
 1950:10   0.019373772176  0.008025867051  0.031591067395
 1950:11   0.024215111048  0.011958579892  0.037914944012
 1950:12   0.029159519325  0.015501857896  0.044441912301
 1951:01   0.034216065342  0.019358934408  0.051518398889
 1951:02   0.039382095852  0.023010227946  0.059069038312
 1951:03   0.044663374412  0.026249568973  0.066963149088
 1951:04   0.050061874348  0.029713046634  0.075076741237
 1951:05   0.055582556225  0.033504518091  0.083531123172
 1951:06   0.061229127529  0.037111289935  0.092302550323
 1951:07   0.067006527529  0.040110305164  0.102090176817
 1951:08   0.072919339319  0.043123463491  0.112024885294
 1951:09   0.078972770553  0.046393611689  0.122553651780
 1951:10   0.085172024329  0.049474494376  0.132875353359
Response of Oil Price to Stock Price Shock in Regime 1
 ENTRY       IRF(2,1)       LOWER(2,1)      UPPER(2,1)
 1950:01  -0.126973869261 -0.313324593326  0.057335812916
 1950:02  -0.062681035767 -0.302693471254  0.176364365026
 1950:03  -0.073751078978 -0.322858945007  0.178651985051
 1950:04  -0.093332867057 -0.343934962766  0.162245264074
 1950:05  -0.114167357860 -0.366703873988  0.141790102613
 1950:06  -0.135032997310 -0.387859494334  0.121106690996
 1950:07  -0.155731411386 -0.411597156901  0.101707849549
 1950:08  -0.176229864758 -0.434159187090  0.079922150907
 1950:09  -0.196524232890 -0.456241525102  0.059622079079
 1950:10  -0.216615506200 -0.479771383160  0.041589737773
 1950:11  -0.236505609807 -0.498388166774  0.024631087482
 1950:12  -0.256196630149 -0.521903274034  0.010643156016
 1951:01  -0.275690666960 -0.547452351450 -0.007238708805
 1951:02  -0.294989804176 -0.570090858712 -0.021529137988
 1951:03  -0.314096104203 -0.594381842511 -0.038737794319
 1951:04  -0.333011606932 -0.613213420689 -0.054956842015
 1951:05  -0.351738329722 -0.635374019599 -0.071736359889
 1951:06  -0.370278267608 -0.657243221170 -0.085392446061
 1951:07  -0.388633393542 -0.679100315539 -0.099362233099
 1951:08  -0.406805658643 -0.702400921974 -0.114868137049
 1951:09  -0.424796992451 -0.722689246660 -0.127909623657
 1951:10  -0.442609303172 -0.744247755795 -0.143407887802
Response of Oil Price to Stock Price Shock in Regime 2
 ENTRY       IRF(2,2)       LOWER(2,2)      UPPER(2,2)
 1950:01   4.980352752923   2.02938543363   7.94693807107
 1950:02   5.313790771885   1.31807021103   9.48443411226
 1950:03   5.683407826706   1.52111672193  10.19889423807
 1950:04   5.275252241618   0.46734886652  10.27097487165
 1950:05   4.904051205403   0.12740888344  10.10434185034
 1950:06   4.376811394265  -0.59839092305   9.80725760299
 1950:07   3.854579178931  -1.15407928153   9.40871615631
 1950:08   3.289984808587  -1.87219359422   9.13635921121
 1950:09   2.721158912044  -2.56049719907   8.69310895295
 1950:10   2.134770394821  -3.23407594949   8.31227483919
 1950:11   1.541138324026  -3.98728229028   7.89815823880
 1950:12   0.935936984359  -4.76738960944   7.50493880465
 1951:01   0.322164954054  -5.54533887900   7.11486643843
 1951:02  -0.301846893166  -6.37964431375   6.64350394690
 1951:03  -0.935280590857  -7.33688108655   6.33005624504
 1951:04  -1.578950880215  -8.19500941070   6.01798710857
 1951:05  -2.232764545950  -9.02128559324   5.64811428731
 1951:06  -2.897246830325  -9.97866623616   5.22245579514
 1951:07  -3.572573724298 -10.96793743553   4.82427844471
 1951:08  -4.259173651998 -11.87590761060   4.44578154593
 1951:09  -4.957337293381 -12.94847174360   4.00160250488
 1951:10  -5.667467150140 -14.03256909851   3.53922646989
Response of Oil Price to Oil Price Shock in Regime 1
 ENTRY       IRF(2,3)       LOWER(2,3)      UPPER(2,3)
 1950:02   0.979760194610  0.963722583136  0.995283813228
 1950:03   0.977686458256  0.962216197942  0.993285489282
 1950:04   0.974804518726  0.958982275112  0.990927138598
 1950:05   0.971918354744  0.955372226473  0.988558214087
 1950:06   0.969052912614  0.951694352013  0.986374451834
 1950:07   0.966214900735  0.948138765386  0.984322712456
 1950:08   0.963405092274  0.944456419634  0.982101581024
 1950:09   0.960623377842  0.940852954699  0.980182673266
 1950:10   0.957869494049  0.937102629059  0.978266034078
 1950:11   0.955143152606  0.933522682363  0.976361136171
 1950:12   0.952444063223  0.930028454252  0.974694217881
 1951:01   0.949771937827  0.926515308470  0.973003264714
 1951:02   0.947126491341  0.922983329483  0.971448433433
 1951:03   0.944507441798  0.919439510563  0.969844882607
 1951:04   0.941914510351  0.915903735021  0.968325658419
 1951:05   0.939347421230  0.912320587527  0.966624624889
 1951:06   0.936805901719  0.908699264376  0.965303921731
 1951:07   0.934289682116  0.905258400712  0.963813021307
 1951:08   0.931798495697  0.901732143926  0.962600082729
 1951:09   0.929332078685  0.898248772510  0.961094324949
 1951:10   0.926890170217  0.895039812579  0.959670700850
Response of Oil Price to Oil Price Shock in Regime 2
 ENTRY       IRF(2,4)       LOWER(2,4)      UPPER(2,4)
 1950:02   0.610280963620  0.444676583861  0.773059703579
 1950:03   0.689146092589  0.626856510806  0.748848452865
 1950:04   0.621216861980  0.534777660859  0.701019826065
 1950:05   0.618276799597  0.564010211885  0.675908061666
 1950:06   0.590770288137  0.532189702543  0.649589615463
 1950:07   0.575365538232  0.521849603311  0.631373462774
 1950:08   0.554583198659  0.497629391199  0.614679323669
 1950:09   0.536445374989  0.473892707325  0.602331457517
 1950:10   0.516773559271  0.447221957061  0.588962318175
 1950:11   0.497652238471  0.418280854743  0.578042612090
 1950:12   0.477911049419  0.390536992004  0.566615107878
 1951:01   0.458166653054  0.360035093157  0.556816040023
 1951:02   0.438044724928  0.328488481593  0.546561800651
 1951:03   0.417744768515  0.296938963928  0.536250410230
 1951:04   0.397131008553  0.266254949602  0.525425246828
 1951:05   0.376270100624  0.234462258261  0.516937339734
 1951:06   0.355105191277  0.202710124706  0.506887812051
 1951:07   0.333656365669  0.170387672119  0.496514887586
 1951:08   0.311894927797  0.137136625491  0.485702907158
 1951:09   0.289823154891  0.103998796764  0.474353462606
 1951:10   0.267422885976  0.073305763594  0.463112305573
You can't see a difference? Regime 1 seems fairly normal, regime 2 has explosive behavior.
zengsongl
Unread post by zengsongl »
TomDoan wrote:You're using an outdated version of the program. The whole MS suite of procedures has changed.
How could we find the updated version of the program?
Best regards,
Zeng
Best regards,
Zeng
You don't "find" it. You buy it. RATS is a copyrighted product.
