Short and Long Run Restrictions,Correlated Structural Shock
abhishek
Unread post by abhishek »
Hi
I am trying to estimate a Structural VAR model with short and long run restrictions and I want one set of structural error to be correlated. Is it possible to do?
Re: Short and Long Run Restrictions,Correlated Structural Sh
Yes, but it's usually the job of the short-run restrictions to get rid of the contemporaneous correlation. (That's how you end up identifying shocks when the long-run restrictions aren't enough).
abhishek
Hi Tom
Thanks for your reply. I need structural shocks to be correlated. Cover et.al.(2005) did this in a three variable set up. Can you tell me a bit about how to do it in Rats? Many Thanks
abhishek
Hi
They had a simple set up that was easy to solve. How to go when we have more number of variables?
Could you please give an actual reference?
abhishek
Thanks Tom. Please find the attached references.
Identifying aggregate demand and supply shocks in a small open economy: Walter Enders and Stan Hurn (2005)
Using the Aggregate Demand-Aggregate Supply Model to Identify Structural Demand-Side and Supply-Side Shocks: Results Using a Bivariate VAR: Cover, Enders and Hueng (2003). Sorry I mentioned 2005 in my earlier post.
http://oep.oxfordjournals.org/content/59/3/411.full
abhishek
Hi Tom
What is the correct format of AFRML? As I am getting error "Identifier AFRML is Not Recognizable". Can I write one element as b(1)*-0.5 where b(1) is the element, I am going to estimate.
abhishek
One more thing, how can we get VAR coefficients after model. I am not talking about print. I mean how we can use them in writing constraints.
abhishek wrote:Hi Tom,
%VARLAGSUMS has all the information needed for doing long-run restrictions.
I assume because you named it something other than AFRML. The A option takes the form A=name of your FRML[RECT]. See the example in the other thread. Yes, you can use that as one element in the FRML.
abhishek
Thanks Tom.
I am getting this error. Can't I do this.
Screen Shot 2016-03-30 at 11.42.02 PM.png (52.83 KiB) Viewed 21378 times
abhishek
I am trying a FIML on the lines of Keating (1990). I am not sure where Rats implements this with A restrictions.
abhishek wrote:Thanks Tom.
Did you actually execute all those instructions? It looks like you tried to do the CVMODEL out-of-sequence. If you execute all those instructions, you can't get that error message.
Aside from that, that model can't possibly work---you have eight free parameters with five in the parameter set and three variances, which is two more than you can have for a three variable covariance matrix.
abhishek wrote:I am trying a FIML on the lines of Keating (1990). I am not sure where Rats implements this with A restrictions.
Again, I would ask you to give full references.
