how to add a text label on a vgrid line in graph ?
applej
Unread post by applej »
I'm trying to denote a horizontal line in a time series graph. I add that line as a threshold bar. Here is my current codes:
set TED1dummy = TED1 >= 0.8
graph(shading = TED1dummy, vgrid=0.8 )
# TED1 1987:7 2014:12
And I want to add a text as : " gamma= 0.8" somewhere above the horizontal line. I checked the RATS manual on graphics, yet haven't found this case. Attached is the look of current graph by the above code. Looking forwards your advise.
Thank you,
J
vgrid.RGF
(2.28 KiB) Downloaded 900 times
Re: how to add a text label on a vgrid line in graph ?
Use GRTEXT. Also https://estima.com/docs/RATS%209%20Intr ... f#page=146. The first example on the help is for a time series graph like yours. Something like
spgraph
  grtext(valign=bottom,y=0.8,entry=2014:12,align=right) "Gamma=.8"
looks like it would work.
applej
TomDoan wrote:Use GRTEXT. Also https://estima.com/docs/RATS%209%20Intr ... f#page=146. The first example on the help is for a time series graph like yours. Something like
spgraph
Thank you very much!
