I'm trying to denote a horizontal line in a time series graph. I add that line as a threshold bar. Here is my current codes:
set TED1dummy = TED1 >= 0.8
graph(shading = TED1dummy, vgrid=0.8 )
# TED1 1987:7 2014:12
And I want to add a text as : " gamma= 0.8" somewhere above the horizontal line. I checked the RATS manual on graphics, yet haven't found this case. Attached is the look of current graph by the above code. Looking forwards your advise.
Thank you,
J
how to add a text label on a vgrid line in graph ?
- vgrid.RGF
- (2.28 KiB) Downloaded 928 times
Re: how to add a text label on a vgrid line in graph ?
Use GRTEXT. Also https://estima.com/docs/RATS%209%20Intr ... f#page=146. The first example on the help is for a time series graph like yours. Something like
spgraph graph(shading = TED1dummy, vgrid=0.8 ) # TED1 1987:7 2014:12 grtext(valign=bottom,y=0.8,entry=2014:12,align=right) "Gamma=.8" spgraph(done)looks like it would work.
Thank you very much!TomDoan wrote:Use GRTEXT. Also https://estima.com/docs/RATS%209%20Intr ... f#page=146. The first example on the help is for a time series graph like yours. Something like
