Balcilar, Gupta and Miller, EE 2015
LvXin
Re: Balcilar, Gupta and Miller, EE 2015
I also could not find which parameters indicate the time duration of regime 1 and regime 2. The time duration means how long will regime 1 or regime 2 will be persistent.
Best Regards!
Best Regards!
Expected duration is 1/(prob remaining in regime).
LvXin
Yes! Thanks very much. I nearly forget this equition! I could caculate it by myself!
Best Regard!
Best Regard!
bekkdcc
I am replicating Balcilar, Gupta and Miller, EE 2015 with their data set and your program (Fuzz" up th............). I can not able to get some values and can not find how to get them.
1. stock-warson cointegration test
2. the prob value of regime properties in Table 4 which are( 0.72 and 0.27)
3. Davies test
4. high - lov volatilty and their count in table 5.
I will be so pleased if you helped me on this issues, cause after I got this informations I am going to do some changes in code for my study, thats why I should to learn these.
3. Davies test
- tables.docx
- (55.85 KiB) Downloaded 1001 times
That's done with the @SWTRENDS procedure. See the swtrends.src file for a description. That isn't used very much.bekkdcc wrote:Dear Tom,
See https://estima.com/forum/viewtopic.php?p=15185. The use of the Davies adjustment for MS models dates back to an earlier paper which summarizes it incorrectly.bekkdcc wrote: 3. Davies test
The "long-run average" probabilities is another name for the ergodic probabilities. %mcergodic(p) will compute those. As to the "actual outcomes", I assume they counted the number of observations where the probability of a particular regime was greater than .5. Since the actual regime is never observable, that's not a particularly meaningful result. The sum of the smoothed probabilities (that is, if the probability of regime 1 is .6, then count regime 1 as .6 and regime 2 as .4) will generally be almost exactly equal to those long-run probabilities. The "actual outcomes" would count the .6 as 1 for regime 1 and 0 for regime 2, even though there is considerable doubt as to which regime actually holds.bekkdcc wrote: 2. the prob value of regime properties in Table 4 which are( 0.72 and 0.27)
bekkdcc
1. I found the function whch is below %mcergodic but it didn not give any number, what shoukd I write at the end of the code to get long-run average" probabilities or ergodic probabilities as a number(value)
function %mcergodic p
type vect %mcergodic
type rect p
local rect a
local integer i j n
compute n=%cols(p)
dim a(n+1,n)
ewise a(i,j)=%if(i>n,1,(i==j)-%if(i<n,p(i,j),1-%sum(%xcol(p,j))))
compute %mcergodic=%xcol(inv(%innerxx(a))*tr(a),n+1)
2. I also want to get loadings in the @johmle, so what should I do
type rect p
local rect a
local integer i j n
compute n=%cols(p)
dim a(n+1,n)
Don't change the function. It produces a VECTOR. Just DISPLAY it.bekkdcc wrote:Dear Tom,
display %mcergodic(p)
Use the LOADINGS option on @JOHMLE.bekkdcc wrote: 2. I also want to get loadings in the @johmle, so what should I do
