Question on Generalized impulse response function
econonick
Dear Sir
I am estimationg generalized impulse response function(Pesaran and Shin, 1998).
But I'm quite confused because the estimated results are differ from EViews.
I am attaching the code and data.
I would really apprecite your help.
Regards
Regards
- example.RPF
- (432 Bytes) Downloaded 1526 times
- result.jpg (52.73 KiB) Viewed 10908 times
- example.prg
- (142 Bytes) Downloaded 1433 times
- example.WF1
- (19.74 KiB) Downloaded 1470 times
- house.dat
- (9.2 KiB) Downloaded 1469 times
Re: Question on Generalized impulse response function
Note that the RATS output is blocked by shocks and the EViews output is blocked by target variable. Once you allow for that, there appears to just be a difference in scaling of the covariance matrix. You'll have to check the EViews documentation to see how they are doing that.
econonick
TomDoan wrote:Note that the RATS output is blocked by shocks and the EViews output is blocked by target variable. Once you allow for that, there appears to just be a difference in scaling of the covariance matrix. You'll have to check the EViews documentation to see how they are doing that.
Dear Tom.
Thank you for your reply.
I find that the different results are "d.f. adjustment" issue.
Sincerely.
