Question on Generalized impulse response function
econonick
Unread post by econonick »
Dear Sir
I am estimationg generalized impulse response function(Pesaran and Shin, 1998).
But I'm quite confused because the estimated results are differ from EViews.
I am attaching the code and data.
I would really apprecite your help.
Regards
example.RPF
(432 Bytes) Downloaded 1574 times
example.prg
(142 Bytes) Downloaded 1480 times
example.WF1
(19.74 KiB) Downloaded 1520 times
house.dat
(9.2 KiB) Downloaded 1515 times
Re: Question on Generalized impulse response function
Note that the RATS output is blocked by shocks and the EViews output is blocked by target variable. Once you allow for that, there appears to just be a difference in scaling of the covariance matrix. You'll have to check the EViews documentation to see how they are doing that.
econonick
TomDoan wrote:Note that the RATS output is blocked by shocks and the EViews output is blocked by target variable. Once you allow for that, there appears to just be a difference in scaling of the covariance matrix. You'll have to check the EViews documentation to see how they are doing that.
Dear Tom.
Thank you for your reply.
I find that the different results are "d.f. adjustment" issue.
Sincerely.
