Do you have an alternative solution as a procedure in RATS?
garchmvbootstrap.rpf
Re: garchmvbootstrap.rpf
In viewtopic.php?p=19882#p19882, I describe a valid test for PoF in overlapping samples. If you aren't satisfied with the Wald test based on QMLE asymptotics, you can block bootstrap the exceedance data and get a bootstrapped distribution for the alphahat. (You don't have to do anything fancy to estimate alphahat since the point estimate is just the fraction of exceedances in each bootstrapped replication).
As an exampleTomDoan wrote: ↑Fri Jan 23, 2026 11:29 am In viewtopic.php?p=19882#p19882, I describe a valid test for PoF in overlapping samples. If you aren't satisfied with the Wald test based on QMLE asymptotics, you can block bootstrap the exceedance data and get a bootstrapped distribution for the alphahat. (You don't have to do anything fancy to estimate alphahat since the point estimate is just the fraction of exceedances in each bootstrapped replication).
https://estima.com/RATSBetaHelp/topics/ ... aprpf.html
calculating p-value: is it always > rather than >=, i.e. not to include the equality, in bootstrapping
* Figure out the bootstrapped p-value
sstats(mean) 1 ndraws (stats>%cdstat)>>pvalue
No. That's a different type of bootstrap (which is bootstrapping data under the null). You need to compare the results with the assumed value of alpha.
I can block bootstrap trigger within a loop, ndraws times, and calculate the means. That's straightforward.
The question is what’s the p-value?
Something like (compare the results with the target value of alpha)
sstats(mean) 1 ndraws %if( abs( Tstar ) > abs( T ),1.0,0.0)>>pvalue
Tstar = (bootstrapping trigger as a mean in a loop) - (actual violation rate e.g. 0.007 in the sample)
T = (actual violation rate e.g. 0.007 in the sample) - (target alpha e.g. 0.01)
And with large ndraws either using > or >= the difference is negligible.
No. You're not bootstrapping to get an estimate of alpha; the mean across bootstrap samples should be roughly the same as the mean of the data. Instead, you're bootstrapping to get the sampling distribution and to compare that to the assumed value of alpha. So you want to count the percentage of times the bootstrapped sample has an alphahat that is on the other side of alpha. (A two-sided test is not easy to construct in this situation). The closest example is bootsimple.rpf (which actually does generate a two-sided test, but that's when doing a sample mean, which symmetrizes more easily than a binomial).
Yes, the mean across bootstrap samples is approximately the same as the mean of the data.
I've plotted alphahatDist.
I don't know how to proceed?TomDoan wrote: ↑Sat Jan 24, 2026 11:06 am So you want to count the percentage of times the bootstrapped sample has an alphahat that is on the other side of alpha. (A two-sided test is not easy to construct in this situation). The closest example is bootsimple.rpf (which actually does generate a two-sided test, but that's when doing a sample mean, which symmetrizes more easily than a binomial).
Here's where I'm at (it's straightforward to do the bootstrap loop and plot the distribution) - I am aiming for a p-value to test for frequency.
procedure acAlphaBlockBoot trigger start end
type series trigger
type integer start end
local integer startl endl
local integer draw N
local real alphahatStar
local series alphahatDist
local series boottrigger
local series[integer] bootentries
option real alpha 0.01
option integer horizon 1
option integer ndraws 10000
* Sample range
# trigger
* Compute observed violation rate
sstats(mean) startl endl trigger>>%%alphahatObs
compute N = %nobs
* Create series to store bootstrap results
set alphahatDist 1 ndraws = 0.0
* Bootstrap loop
do draw = 1, ndraws
* Generate bootstrap block indices from the actual data range
BOOT(block=horizon) bootentries startl endl startl endl
* Resample the ACTUAL trigger series using those indices
set boottrigger startl endl = trigger(bootentries(t))
* Compute violation rate for this bootstrap sample
sstats(mean) startl endl boottrigger>>alphahatStar
compute alphahatDist(draw) = alphahatStar
end do draw
* Compute bootstrap statistics
stats(fractiles) alphahatDist 1 ndraws
compute %%bootmean = %mean
compute %%bootse = sqrt(%variance)
* --- Plot density function for alphabootdist ---
density(smoothing=2.0) alphahatDist 1 ndraws galphaboot falphaboot
* 10 horizons, 10 colours
compute col = %if(horizon==1,2,$
%if(horizon==2,4,$
%if(horizon==3,5,$
%if(horizon==4,6,$
%if(horizon==5,7,$
%if(horizon==6,8,$
%if(horizon==7,9,$
%if(horizon==8,10,$
%if(horizon==9,11,12)))))))))
spgraph(hea="",vfi=1,hfi=1)
scatter(key=upright,head="A non-parametric empirical approximation to the sampling distribution",$
hgrid=||%%bootmean||,style=line) 1
# galphaboot falphaboot 1 ndraws col
* --- Output Results ---
disp "=================================================="
disp " Alpha Block Bootstrap Unconditional Coverage Test"
disp "Horizon (horizon): " horizon
disp "Sample size (N): " N
disp "Target alpha: " alpha
disp "Observed alphahat: " %%alphahatObs
disp "Bootstrap mean: " %%bootmean
disp "Bootstrap SE: " %%bootse
end procedure
Compute the percentage of draws that are on the wrong side of the hypothesized alpha.
sstats(mean) 1 ndraws (alphahatDist>alpha)>>pctover (alphadataDist<alpha)>>pctunder
whichever of pctover and pctunder is appropriate. See the first example in the description of SSTATS.
