Forecasting Actual Series with @MVGarchFore
victor
Unread post by victor »
Hello Tom,
This is a part of GARCHMV example. I have two questions
1) How to forecast actual (xjpn), actual series
2) When I run this code @MVGarchfore seems to run fine but when I give print command for hh or print us, I don't get any thing in out put.
MVForecasting.PRG
(599 Bytes) Downloaded 894 times
Re: Forecasting Actual Series with @MVGarchFore
victor wrote:Hello Tom,
Just use a standard FORECAST instruction on the model.
victor wrote: 2) When I run this code @MVGarchfore seems to run fine but when I give print command for hh or print us, I don't get any thing in out put.
You have to extract the information from the HH and US, which are series of SYMMETRICS and VECTORS, respectively. See the end of the GARCHMV.RPF example.
