Hello Tom,
This is a part of GARCHMV example. I have two questions
1) How to forecast actual (xjpn), actual series
2) When I run this code @MVGarchfore seems to run fine but when I give print command for hh or print us, I don't get any thing in out put.
Forecasting Actual Series with @MVGarchFore
victor
- MVForecasting.PRG
- (599 Bytes) Downloaded 967 times
Re: Forecasting Actual Series with @MVGarchFore
Just use a standard FORECAST instruction on the model.victor wrote:Hello Tom,
You have to extract the information from the HH and US, which are series of SYMMETRICS and VECTORS, respectively. See the end of the GARCHMV.RPF example.victor wrote: 2) When I run this code @MVGarchfore seems to run fine but when I give print command for hh or print us, I don't get any thing in out put.
