sorry for bothering.
I am running a Bayesian VAR with sign restrictions of order m=4 variables and I want to identify 4 shocks.
The code looks ok, and it produces IRF and FEVD as I desire.
However, I do not get why the FEVD do not sum to 100, but around 90-95 (see, for example, output-gap columns).
Does it come from the median? Should it be overcame by using the Fry-Pagan correction?
My guess is that the code I am running, provided it is correct, should achieve a full decomposition, i.e. sum 100, regardless of the Fry-Pagan correction.
Could you please give me some hints?
Thanks in advance for taking the time to answer.
KOBE
full identification-FEVD problem
- main_2013.xls
- (52 KiB) Downloaded 731 times
- main_2013.RPF
- (14.39 KiB) Downloaded 1094 times
Re: full identification-FEVD problem
There's no reason for the medians to sum to 100%. The means would have to, but because of the asymmetry, the means can be outside bounds generated using percentiles.KOBE24 wrote:Dear Tom,
KOBE
The best advice is to not be all that concerned about error bands for FEVD's.
Got it.
Thank you Tom: I have accordingly modified the code (%avg(work) instead of frac(2)) and it is perfect now.
Your help is really appreciated!
KOBE
KOBE
