full identification-FEVD problem
KOBE24
Unread post by KOBE24 »
sorry for bothering.
I am running a Bayesian VAR with sign restrictions of order m=4 variables and I want to identify 4 shocks.
The code looks ok, and it produces IRF and FEVD as I desire.
However, I do not get why the FEVD do not sum to 100, but around 90-95 (see, for example, output-gap columns).
Does it come from the median? Should it be overcame by using the Fry-Pagan correction?
My guess is that the code I am running, provided it is correct, should achieve a full decomposition, i.e. sum 100, regardless of the Fry-Pagan correction.
Could you please give me some hints?
Thanks in advance for taking the time to answer.
KOBE
main_2013.xls
(52 KiB) Downloaded 839 times
main_2013.RPF
(14.39 KiB) Downloaded 1224 times
Re: full identification-FEVD problem
KOBE24 wrote:Dear Tom,
KOBE
There's no reason for the medians to sum to 100%. The means would have to, but because of the asymmetry, the means can be outside bounds generated using percentiles.
The best advice is to not be all that concerned about error bands for FEVD's.
KOBE24
Got it.
Thank you Tom: I have accordingly modified the code (%avg(work) instead of frac(2)) and it is perfect now.
Your help is really appreciated!
KOBE
