Problem with @CONDITION
Ozmando
Dear Users,
I am trying to run a code in Rats 8.2 but get the following message after 2100 iterations:
"## OP9. Options MODEL and parameter list of equations May Not Be Used Together
## OP3. This Instruction Does Not Have An Option DEC
>>>> @condition(decomp=<<<<"
The code was originally written using Rats 6.0.
I was wondering if anyone can help with this please.
Oz
PS: Would have been easier to post the code; but got it from somebody and do not have permission to make it public. Sorry for this.
Oz
Re: Help with error please
Those are two different errors. For the second, on 8.2 the DECOMP option on @CONDITION is replaced by FACTOR, so you just have to replace DECOMP= with FACTOR=. For the first, it sounds as if you have an instruction
SYSTEM(MODEL=...) list of equations
If you're using MODEL, you don't want the "list of equations".
Ozmando
Hi Tom, Thanks for your reply.TomDoan wrote:Those are two different errors. For the second, on 8.2 the DECOMP option on @CONDITION is replaced by FACTOR, so you just have to replace DECOMP= with FACTOR=. For the first, it sounds as if you have an instruction
I have done the changes but now get this error:
## SX22. Expected Type INTEGER, Got MODEL Instead
>>>>r=chole) varmodel1 <<<<
With regard to ##OP9: this is the portion of the code:
system(model=varmodel1) 1 to nvar
variables usinf usinfr useg usgdpg jpinf jpinfr jpeg jpgdpg $
geinf geinfr geeg gegdpg ukinf ukinfr ukeg ukgdpg $
frinf frinfr freg frgdpg itinf itinfr iteg itgdpg $
cainf cainfr caeg cagdpg
lags 1 to nlags
Many thanks,
oz
You want just
for the first line.
On the @CONDITION procedure call, you want to use MODEL=VARMODEL1 as one of the options. The parameter should be the number of constraints, not the model name.
for the first line.
Ozmando
TomDoan wrote:You want just
for the first line.
Many thanks again. With your suggestion one of the problem is now solved. But still struggling with the one related to @CONDITION
Will look through the RATS programming manual but this is the actual portion of the code:
@condition(factor=chole) varmodel1 nstep tempend+1 sigm 2 condfore
# usgdpg tempend+1 usgdpg(tempend)+1.
* # usgdpg tempend+2 usgdpg(tempend)+.5
* # usgdpg tempend+3 usgdpg(tempend)+.25
* # usgdpg tempend+4 usgdpg(tempend)
# useg tempend+1 useg(tempend)+1.
* # useg tempend+2 usgdpg(tempend)+.5
forecast(model=varmodel1,results=forecasts) nvar nstep tempend+1
Many thanks,
oz
The version 6 procedure for this was called CNDITION (without the O) and had a different syntax---it used parameters rather than options. If you just have the one program, I would probably just re-do the procedure call to use the more modern syntax. Otherwise, use this instead:
* CNDITION.SRC
* Computes conditional forecasts. See Section 10.14 of the Manual
* Syntax:
* @CNDITION( options ) model steps start VCV Matrix constraints forecasts
* # series entry value (one for each constraint)
* or
* @CNDITION(GENERAL,other options ) model steps start VCV Matrix constraints forecasts
* # vector with linear combination of endogenous variables (one pair for each constraint)
* # entry value
* model = VAR model used for forecasts
* steps = number of forecast steps
* start = start period of forecast
* VCV Matrix = SYMMETRIC covariance matrix of residuals. The rows must
* correspond to equations in order
* constraints = number of constraints on future values
* forecasts = VECT[SERIES] containing the constrained forecasts. This
* is returned by the procedure.
* Supplementary Cards, first type (one for each constraint)
* series = endogenous variable constrained
* entry = entry of constraint
* value = target value
* Supplementary Cards, second type (one of each for each constraint)
* vector ... = VECTOR or real numbers/expressions with linear combination of
* endogenous variables to constrain
* value = target value for the linear combination
* Options
* general/[nogeneral] use GENERAL to use constraints on linear combinations of series, rather
* than on individual variables
* shocks = VECT[SERIES] with the orthogonalized shocks used
* decomp = factorization matrix [Choleski factor of VCV matrix]
* simulate/[nosimulate] if simulated, draws randomly from the constrained density
* Revision Schedule
* 12/03 SIMULATE option added
* 01/05 GENERAL option added
procedure cndition model nfore nbeg vmat nconstr fcstout
type model model
type integer nfore nbeg nconstr
type vect[series] *fcstout
type symmetric vmat
option switch simulate 0
option rect decomp
option vect[series] *shocks
option switch general 0
local integer nvar
local index step var
local vector value
local integer i j nsteps nfree constr consentr enumber
local rect capr uover vover vdecomp overr
local vect lowr u v
local rect[series] impfunc
local vect[integer] depvars
local vect[vect] lcomb
local symm rrrr
* Process supplementary cards for PROCEDURE.
dimension step(nconstr) var(nconstr) value(nconstr) lcomb(nconstr)
compute nvar=%modelsize(model)
compute nsteps=0
do i=1,nconstr
if .not.general
enter var(i) step(i) value(i)
else {
dim lcomb(i)(nvar)
enter lcomb(i)
enter step(i) value(i)
compute step(i)=step(i)-nbeg+1
if step(i)>nsteps ; compute nsteps=step(i)
* Replace VAR(I) with the equation which has VAR(I) as its dependent
* variable.
compute depvars=%modeldepvars(model)
if .not.general {
do i=1,nconstr
compute enumber=0
do j=1,nvar
if var(i)==depvars(j) {
compute enumber=j
break
if enumber==0 {
display 'Constraints Must Use One of the Endogenous Variables'
display 'Please Check Constraint Number' I
return
compute var(i)=enumber
if %defined(decomp)
compute vdecomp=decomp
else
compute vdecomp=%decomp(vmat)
forecast(model=model,results=fcstout) * nsteps nbeg
impulse(model=model,results=impfunc,noprint,decomp=vdecomp) * nsteps *
compute nfree=nvar*nsteps
dimension capr(nfree,nconstr) vdecomp(nvar,nvar)
dimension u(nfree) v(nfree) lowr(nconstr)
do constr=1,nconstr
if .not.general
compute lowr(constr)=value(constr)-fcstout(var(constr))(step(constr)+nbeg-1)
else
compute lowr(constr)=value(constr)-%dot(lcomb(constr),%xt(fcstout,step(constr)+nbeg-1))
overlay capr(1,constr) with overr(nsteps,nvar)
compute consentr=1+step(constr)
if .not.general
ewise overr(i,j)=%if(i<consentr,impfunc(var(constr),j)(consentr-i),0.0)
else
ewise overr(i,j)=%if(i<consentr,%dot(lcomb(constr),%xcol(%xt(impfunc,consentr-i),j)),0.0)
end do constr
* Compute optimal orthogonalized V
compute v=capr*inv( tr(capr)*capr )*lowr
overlay u(1) with uover(nsteps,nvar)
overlay v(1) with vover(nsteps,nvar)
* If simulations are requested, do a draw from the constrained
* density for the orthogonal shocks
if simulate {
compute rrrr=%identity(nsteps*nvar)-capr*inv(tr(capr)*capr)*tr(capr)
compute v=v+%ranmvnormal(%decomp(rrrr))
* Transform to non-orthogonal U
compute uover=vover*tr(vdecomp)
* Save the orthogonalized shocks
if %defined(shocks) {
dim shocks(nvar)
do i=1,nvar
set shocks(i) nbeg nbeg+nsteps-1 = vover(t-nbeg+1,i)
* Forecast with U shocks
forecast(model=model,matrix=uover,results=fcstout) * nfore nbeg
end cndition
Ozmando
TomDoan wrote:The version 6 procedure for this was called CNDITION (without the O) and had a different syntax---it used parameters rather than options. If you just have the one program, I would probably just re-do the procedure call to use the more modern syntax. Otherwise, use this instead:
* * CNDITION.SRC * Computes conditional forecasts. See Section 10.14 of the Manual * * Syntax: * * @CNDITION( options ) model steps start VCV Matrix constraints forecasts * # series entry value (one for each constraint) * * or * * @CNDITION(GENERAL,other options ) model steps start VCV Matrix constraints forecasts * # vector with linear combination of endogenous variables (one pair for each constraint) * # entry value * * model = VAR model used for forecasts * steps = number of forecast steps * start = start period of forecast * VCV Matrix = SYMMETRIC covariance matrix of residuals. The rows must * correspond to equations in order * constraints = number of constraints on future values * forecasts = VECT[SERIES] containing the constrained forecasts. This * is returned by the procedure. * * Supplementary Cards, first type (one for each constraint) * series = endogenous variable constrained * entry = entry of constraint * value = target value * * Supplementary Cards, second type (one of each for each constraint) * vector ... = VECTOR or real numbers/expressions with linear combination of * endogenous variables to constrain * entry = entry of constraint * value = target value for the linear combination * * Options * general/[nogeneral] use GENERAL to use constraints on linear combinations of series, rather * than on individual variables * shocks = VECT[SERIES] with the orthogonalized shocks used * decomp = factorization matrix [Choleski factor of VCV matrix] * simulate/[nosimulate] if simulated, draws randomly from the constrained density * * Revision Schedule * 12/03 SIMULATE option added * 01/05 GENERAL option added * procedure cndition model nfore nbeg vmat nconstr fcstout type model model type integer nfore nbeg nconstr type vect[series] *fcstout type symmetric vmat * option switch simulate 0 option rect decomp option vect[series] *shocks option switch general 0 * local integer nvar local index step var local vector value local integer i j nsteps nfree constr consentr enumber local rect capr uover vover vdecomp overr local vect lowr u v local rect[series] impfunc local vect[integer] depvars local vect[vect] lcomb local symm rrrr * * Process supplementary cards for PROCEDURE. * dimension step(nconstr) var(nconstr) value(nconstr) lcomb(nconstr) * compute nvar=%modelsize(model) compute nsteps=0 do i=1,nconstr if .not.general enter var(i) step(i) value(i) else { dim lcomb(i)(nvar) enter lcomb(i) enter step(i) value(i) } compute step(i)=step(i)-nbeg+1 if step(i)>nsteps ; compute nsteps=step(i) end do i * * Replace VAR(I) with the equation which has VAR(I) as its dependent * variable. * compute depvars=%modeldepvars(model) if .not.general { do i=1,nconstr compute enumber=0 do j=1,nvar if var(i)==depvars(j) { compute enumber=j break } end do j if enumber==0 { display 'Constraints Must Use One of the Endogenous Variables' display 'Please Check Constraint Number' I return } compute var(i)=enumber end do i } if %defined(decomp) compute vdecomp=decomp else compute vdecomp=%decomp(vmat) forecast(model=model,results=fcstout) * nsteps nbeg impulse(model=model,results=impfunc,noprint,decomp=vdecomp) * nsteps * compute nfree=nvar*nsteps dimension capr(nfree,nconstr) vdecomp(nvar,nvar) dimension u(nfree) v(nfree) lowr(nconstr) do constr=1,nconstr if .not.general compute lowr(constr)=value(constr)-fcstout(var(constr))(step(constr)+nbeg-1) else compute lowr(constr)=value(constr)-%dot(lcomb(constr),%xt(fcstout,step(constr)+nbeg-1)) overlay capr(1,constr) with overr(nsteps,nvar) compute consentr=1+step(constr) if .not.general ewise overr(i,j)=%if(i<consentr,impfunc(var(constr),j)(consentr-i),0.0) else ewise overr(i,j)=%if(i<consentr,%dot(lcomb(constr),%xcol(%xt(impfunc,consentr-i),j)),0.0) end do constr * * Compute optimal orthogonalized V * compute v=capr*inv( tr(capr)*capr )*lowr overlay u(1) with uover(nsteps,nvar) overlay v(1) with vover(nsteps,nvar) * * If simulations are requested, do a draw from the constrained * density for the orthogonal shocks * if simulate { compute rrrr=%identity(nsteps*nvar)-capr*inv(tr(capr)*capr)*tr(capr) compute v=v+%ranmvnormal(%decomp(rrrr)) } * * Transform to non-orthogonal U * compute uover=vover*tr(vdecomp) * * Save the orthogonalized shocks * if %defined(shocks) { dim shocks(nvar) do i=1,nvar set shocks(i) nbeg nbeg+nsteps-1 = vover(t-nbeg+1,i) end do i } * * Forecast with U shocks * forecast(model=model,matrix=uover,results=fcstout) * nfore nbeg end cndition
Thanks so much again. Need to clarify that I am using rats 8.2 (although the program that I am trying to run was written by someone using Rats 6.0). I have, therefore, changed the "CNDITION" to the "CONDITION". I have done all changes in the source code accordingly.
I am going through the code step by step to understand the source of the problem.
thanks,
Oz
Ozmando
Many thanks Tom for your help.
Both @CNDITION and @CONDITION are working fine with RATS 8.2
Much appreciated.
oz
Much appreciated.
oz
