Problem with @CONDITION
Ozmando
Unread post by Ozmando »
Dear Users,
I am trying to run a code in Rats 8.2 but get the following message after 2100 iterations:
"## OP9. Options MODEL and parameter list of equations May Not Be Used Together
## OP3. This Instruction Does Not Have An Option DEC
>>>> @condition(decomp=<<<<
The code was originally written using Rats 6.0.
I was wondering if anyone can help with this please.
Oz
PS: Would have been easier to post the code; but got it from somebody and do not have permission to make it public. Sorry for this.
Re: Help with error please
Those are two different errors. For the second, on 8.2 the DECOMP option on @CONDITION is replaced by FACTOR, so you just have to replace DECOMP= with FACTOR=. For the first, it sounds as if you have an instruction
SYSTEM(MODEL=...) list of equations
If you're using MODEL, you don't want the "list of equations".
Ozmando
TomDoan wrote:Those are two different errors. For the second, on 8.2 the DECOMP option on @CONDITION is replaced by FACTOR, so you just have to replace DECOMP= with FACTOR=. For the first, it sounds as if you have an instruction
Hi Tom, Thanks for your reply.
I have done the changes but now get this error:
## SX22. Expected Type INTEGER, Got MODEL Instead
>>>>r=chole) varmodel1 <<<<
With regard to ##OP9: this is the portion of the code:
system(model=varmodel1) 1 to nvar
variables usinf usinfr useg usgdpg jpinf jpinfr jpeg jpgdpg $
geinf geinfr geeg gegdpg ukinf ukinfr ukeg ukgdpg $
frinf frinfr freg frgdpg itinf itinfr iteg itgdpg $
cainf cainfr caeg cagdpg
lags 1 to nlags
Many thanks,
oz
You want just
for the first line.
On the @CONDITION procedure call, you want to use MODEL=VARMODEL1 as one of the options. The parameter should be the number of constraints, not the model name.
Ozmando
TomDoan wrote:You want just
for the first line.
Many thanks again. With your suggestion one of the problem is now solved. But still struggling with the one related to @CONDITION
Will look through the RATS programming manual but this is the actual portion of the code:
@condition(factor=chole) varmodel1 nstep tempend+1 sigm 2 condfore
# usgdpg tempend+1 usgdpg(tempend)+1.
* # usgdpg tempend+2 usgdpg(tempend)+.5
* # usgdpg tempend+3 usgdpg(tempend)+.25
* # usgdpg tempend+4 usgdpg(tempend)
# useg tempend+1 useg(tempend)+1.
* # useg tempend+2 usgdpg(tempend)+.5
forecast(model=varmodel1,results=forecasts) nvar nstep tempend+1
Many thanks,
oz
The version 6 procedure for this was called CNDITION (without the O) and had a different syntax---it used parameters rather than options. If you just have the one program, I would probably just re-do the procedure call to use the more modern syntax. Otherwise, use this instead:
*  CNDITION.SRC
*  Computes conditional forecasts. See Section 10.14 of the Manual
*  Syntax:
*  @CNDITION( options )  model  steps  start  VCV Matrix  constraints  forecasts
*  #  series   entry    value  (one for each constraint)
*     or
*  @CNDITION(GENERAL,other options )  model  steps  start  VCV Matrix  constraints  forecasts
*  #  vector with linear combination of endogenous variables (one pair for each constraint)
*  #  entry value
*    model       = VAR model used for forecasts
*    steps       = number of forecast steps
*    start       = start period of forecast
*    VCV Matrix  = SYMMETRIC covariance matrix of residuals. The rows must
*                  correspond to equations in order
*    constraints = number of constraints on future values
*    forecasts   = VECT[SERIES] containing the constrained forecasts. This
*                  is returned by the procedure.
*  Supplementary Cards, first type (one for each constraint)
*    series      = endogenous variable constrained
*    entry       = entry of constraint
*    value       = target value
*  Supplementary Cards, second type (one of each for each constraint)
*    vector ...  = VECTOR or real numbers/expressions with linear combination of
*                    endogenous variables to constrain
*    value       = target value for the linear combination
*  Options
*    general/[nogeneral] use GENERAL to use constraints on linear combinations of series, rather
*                        than on individual variables
*    shocks = VECT[SERIES] with the orthogonalized shocks used
*    decomp = factorization matrix [Choleski factor of VCV matrix]
*    simulate/[nosimulate] if simulated, draws randomly from the constrained density
*  Revision Schedule
*    12/03 SIMULATE option added
*    01/05 GENERAL option added
procedure cndition  model nfore nbeg vmat nconstr fcstout
type model model
type integer nfore nbeg nconstr
type vect[series] *fcstout
type symmetric vmat
option switch        simulate 0
option rect          decomp
option vect[series] *shocks
option switch        general 0
local integer nvar
local index step var
local vector value
local integer i j nsteps nfree constr consentr enumber
local rect capr uover vover vdecomp overr
local vect lowr u v
local rect[series] impfunc
local vect[integer] depvars
local vect[vect] lcomb
local symm rrrr
*   Process  supplementary cards for PROCEDURE.
dimension step(nconstr) var(nconstr) value(nconstr) lcomb(nconstr)
compute nvar=%modelsize(model)
compute nsteps=0
do i=1,nconstr
  if .not.general
     enter var(i) step(i) value(i)
  else {
     dim lcomb(i)(nvar)
     enter lcomb(i)
     enter step(i) value(i)
  compute step(i)=step(i)-nbeg+1
  if step(i)>nsteps  ; compute nsteps=step(i)
*  Replace VAR(I) with the equation which has VAR(I) as its dependent
*  variable.
compute depvars=%modeldepvars(model)
if .not.general {
   do i=1,nconstr
      compute enumber=0
      do j=1,nvar
         if var(i)==depvars(j) {
            compute enumber=j
            break
      if enumber==0 {
         display 'Constraints Must Use One of the Endogenous Variables'
         display 'Please Check Constraint Number' I
         return
      compute var(i)=enumber
if %defined(decomp)
   compute vdecomp=decomp
else
   compute vdecomp=%decomp(vmat)
forecast(model=model,results=fcstout) * nsteps nbeg
impulse(model=model,results=impfunc,noprint,decomp=vdecomp) * nsteps *
compute nfree=nvar*nsteps
dimension capr(nfree,nconstr) vdecomp(nvar,nvar)
dimension u(nfree) v(nfree) lowr(nconstr)
do constr=1,nconstr
   if .not.general
      compute lowr(constr)=value(constr)-fcstout(var(constr))(step(constr)+nbeg-1)
   else
      compute lowr(constr)=value(constr)-%dot(lcomb(constr),%xt(fcstout,step(constr)+nbeg-1))
   overlay capr(1,constr) with overr(nsteps,nvar)
   compute consentr=1+step(constr)
   if .not.general
      ewise overr(i,j)=%if(i<consentr,impfunc(var(constr),j)(consentr-i),0.0)
   else
      ewise overr(i,j)=%if(i<consentr,%dot(lcomb(constr),%xcol(%xt(impfunc,consentr-i),j)),0.0)
end do constr
*  Compute optimal orthogonalized V
compute v=capr*inv( tr(capr)*capr )*lowr
overlay u(1) with uover(nsteps,nvar)
overlay v(1) with vover(nsteps,nvar)
*  If simulations are requested, do a draw from the constrained
*  density for the orthogonal shocks
if simulate {
   compute rrrr=%identity(nsteps*nvar)-capr*inv(tr(capr)*capr)*tr(capr)
   compute v=v+%ranmvnormal(%decomp(rrrr))
*  Transform to non-orthogonal U
compute uover=vover*tr(vdecomp)
*  Save the orthogonalized shocks
if %defined(shocks) {
   dim shocks(nvar)
   do i=1,nvar
      set shocks(i) nbeg nbeg+nsteps-1 = vover(t-nbeg+1,i)
*   Forecast with U shocks
forecast(model=model,matrix=uover,results=fcstout) * nfore nbeg
end cndition
Ozmando
TomDoan wrote:The version 6 procedure for this was called CNDITION (without the O) and had a different syntax---it used parameters rather than options. If you just have the one program, I would probably just re-do the procedure call to use the more modern syntax. Otherwise, use this instead:
*  CNDITION.SRC
*  Syntax:
*     or
*  #  entry value
*  Options
*  Revision Schedule
type model model
type symmetric vmat
option rect          decomp
local integer nvar
local vector value
local vect lowr u v
local symm rrrr
compute nsteps=0
do i=1,nconstr
  if .not.general
  else {
     dim lcomb(i)(nvar)
     enter lcomb(i)
*  variable.
if .not.general {
   do i=1,nconstr
      compute enumber=0
      do j=1,nvar
            compute enumber=j
            break
      if enumber==0 {
         return
if %defined(decomp)
else
do constr=1,nconstr
   if .not.general
   else
   if .not.general
   else
end do constr
if simulate {
   dim shocks(nvar)
   do i=1,nvar
end cndition
Thanks so much again. Need to clarify that I am using rats 8.2 (although the program that I am trying to run was written by someone using Rats 6.0). I have, therefore, changed the "CNDITION" to the "CONDITION". I have done all changes in the source code accordingly.
I am going through the code step by step to understand the source of the problem.
thanks,
Oz
Ozmando
Many thanks Tom for your help.
Both @CNDITION and @CONDITION are working fine with RATS 8.2
Much appreciated.
oz
